Question about Refrigerators
I have a walk in freezer at work that the coils slowly freeze. i forced defrost using the timer, element not coming on, help
  • Refrigerators Master
  • 43,501 Answers
That could be the defrost timer or the heating elements....force it into defrost again and then check the elements for power...if no power it is the timer...now the coils will have 120 to them but you want 240v across the element...
heatman101
Posted on Sep 14, 2010
The freezer still goes but not the fridge part.
You have a unit whose defrost cycle isn't working properly. The defrost element is either controlled by an actual timer motor or it may be controlled by a circuit board. Either the defrost element is defective, the defrost timer is defective or the circuit board is defective. A very remote possibility is the defrost termination thermostat could be 'open'.
If you TOTALLY defrost the freezer compartment, your unit will work decently for about three days until it freezes solid again. The evaporator coil in the freezer is covered by the interior and inaccessible without removing the freezer shelving and the rear of the freezer interior. If the element is defective, it is located behind this cover and is imbedded within the evaporator coil itself.
Feb 20, 2015 | Refrigerators
Frigidaire side by side model # FRS20ZRGW3 coils freeze up on freezer side, fridge side gets warm
You have a defrost timer behind the front kick plate turn it clockwise slowly until compressor and fans stop. Once this happens the timer should remain off for 30 minutes and the defrost heater should come on during the first 15 minutes. If after 30 minutes the defrost timer part=> 215846602 Defrost Timer Assembly should come out of defrost and the compressor and fans should restart, if not advance the timer clockwise until they start and replace timer. Try that first and tell me what your results are. If that is not the problem then we can narrow this down to the defrost heater=> 218657301 Defrost Heater or 5303917954 Defrost Thermostat How to test the defrost heater is found on same page as the defrost heater. If you have any questions I will be here to help you, Thanks Sea Breeze
Apr 22, 2012 | Frigidaire Refrigerators
Freezer Coil freezing over.
You have either a defrost timer, defrost thermostat or defrost element that is bad.Before you defrost, use an ohmmeter to check the defrost thermostat to see if it is closed. If it is , defrost and check the defrost element for continuity. If it has verry little resistance , you have a bad defrost timer.
Apr 05, 2011 | Magic Chef CTB1502AR Top Freezer...
My freezer does not freez well.. What to do? Refrigirator DAEWOO FR-291
Most likely you are having a defros problem. Inspect back wall of freezer for frost build-up. Or better yet, remove freezer panel to check coils for excessive ice or frost buildup.
The problem could be with you heating element, defrost terminator, or defrost timer. Manually turn the timer slowly, very slowly, until it clicks. May take you several tries to get it on defrost cycle. Onece it clicks, stop. Now look at the heating element to seee if its getting hot, or listen for crackling sounds. If the heater turns on, then the pproblem is with the timer. If it doesnt come on, then the heater is bad. You can also inspect it and check for continuity. inspect the terminator, as well, it is clippe to the suction line on the evaporator. If its bulging or deformed, then its no good.
If the freezer is iced up, the problem will be with the timer or heater.
If freezer is not cooling and everything is melting problem is with terminator.
Mar 05, 2011 | LG Refrigerators
Refrigerator not cold and ice keeps building up in lower freezer unit all over .keep defrosting and runs good and then same problem.
Your defrost timer is bad or your heating element. The defrost timer in newer models is inside the fridge side under the plastic cover in the back or if you have a light and dial themostat dial in the top centre its there. The timer will be black with a shaft in the center that a flatblade screw driver can turn. Turn it slowly one click at a time until the fan and compressor kick off. (the fan in the fzr will kick off also) You can hear audible clicks but go slow the defrost mode is just one click of the dial and it may take you a few minutes to hit the spot. When the fan and compressor stops wait about 3 minutes and listen to the freezer you should hear hissing and popping ice sounds if you dont you need to defrost the freezer and take the back off so you can see the cooling coils you may have to defrost it even more once the coils is exsposed. You will see a black heating element (or a glass one with an element inside rare) this element will be attached to the cooling coil and on one end of it will be a nikle size disc this is the defrost limit it keeps the heating element from getting to hot for to long. If the element is bad it will usually have a spot in it blown out and burnt. You can ck the element with an ohm/volt meter these can be picked up at any hardware store for 5 to 15 dollars. It will come with directions on how to use it. But either your defrost timer,element,or thermal limit is out. If you have any trouble let me know and I will walk you thru it. good luck and respect the electricity and unplug the fridge before testing parts.
Aug 16, 2010 | Amana Refrigerators
Freezer side of refridgerator doesn't freeze foods properly and also makes only about 10 cubes a day. food side works fine, it's a Hotpoint model #HSS251FMB WW
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Refrigerators
My top freezer refridgerator has slowly quit cooling very well. The freezer works fine and we have checked that the fan is running, we also cleaned the coils. What else can I do?
Freezer not freezing
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not freezing it is staying on 30degree
The defrost system has failed and is not de-icing the coil or, the door is not sealing tight or too much time open allowing excess humidity to enter the chamber, thereby overcoming the capabilities of the defrost system. The system has a defrost timer someplace, check to see if it is running. If not, you can probably advance it into a defrost cycle with a screwdriver. (turn the shaft slowly until a click is heard and the system stops) Allow 20 or 30 minutes for the coils to defrost, and restart with the screwdriver if it has not took off on it's own. If the timer is found not running, replace it.
May 25, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Apr 22, 2009 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
