Question about Olympus VN-4100PC Digital Voice Recorder
Just need to know how long it will record if continually run?
    Genius:
  • 1,218 Answers
Max. recording time is approx.144hrs20mins in LP mode.
11hrs40mins in XHQ mode.
Posted on Sep 14, 2010
The tone arm drops onto the record, but then continues moving across the record without playing the record. Anyone know what's going on?
Does the needle actually contact the record? If not, you may be missing a "pad" under the record, or you may be simply missing the needle that needs to be there to follow the grooves.
Nov 02, 2014 | Audio Players & Recorders
My H.264 recorder has stopped recording--the 4 cameras still show on monitor
There are a number of possibilities. 1st: Make sure the record button is activated. (Simple I know: but check it!).2nd: Go into the menu & make sure that the camera's are all set to continuous record, not motion detect or schedule record. 3rd:Check hard drive status. If your hard drive does not appear in the hard drive section, it means it has failed & needs to be replaced.
Samuel Morris
Camtek Of NY Inc
Oct 13, 2014 | Home Security
Trying to record from tv set to analog press rec opt flashes for 10 sec+- then rec flashes continuously and no signal strength/vol bars
I think there is no cd in the tray or your recorder had set in pause mode .
Let me know if you need more information
Thanks
Feb 01, 2011 | Sony RCD-W1 2-Disc CD Recorder
Fan on Dish Network's VIP722k DVR is continually running.
Hello, this is Nick Franta with DISH Network Customer Support.
It is normal for the fan on the 722k receiver to run often to cool down the system. If the receiver is in an enclosed space that could cause the receiver to overheat which would make the fan run continuously.
If you have any further questions let us know.
Dec 11, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Tape will not run
The "will not run problem" was solved by replacing the CR-2025 Lithium battery. The eject symbol continues to appear sometimes and I can remove it and continue operating the camera by turning the power supply "Off then On" again. Camera is now running a recorded cassette but quality of picture is low.
Jan 14, 2010 | Sony Handycam CCD-TRV68 Camcorder
Chkdsk will not run
You need to run chkdsk /F /X and then the drive letter c: for example.
May 03, 2009 | Seagate USB 2.0 External Enclosure + 400GB...
Continuous beep
Hello. The TRC8080 will coontinously beep when trying to record if the tab switch (this is described in the service manual a Tab Switch S3, S4) fails. The tab switch consists of two leaf switches one is so the machine know there is a tape in the machine and the other check for record protect. Over a period of time thee canbecomebent anwill not always connect when a tape is in. This wll result in you either not being able to play a casette or not being able to record depending on which one fails. These can only be replaced as a pair. If it is not the tab switch which has failed then the cassette tabs on the top may be bent in slightly which means you will need to replace the cassette.
If the tab switch has failed and you dont want to pay for a repair you take the 5 screws out of the back of the machine, lift the top cabinet off (disconnect the single molex connector) and short the switches together. (Solder is best) this will leave the switches perminatly in the 'on' position meaning you can dictate away.
Remember if you shoose to short the switches together the motor will run as soon as the cassette lid is closed and the machine is on. This may make the motor fail a little bit earlier than normal.
Apr 24, 2009 | Sanyo TRC-8080 Desktop Cassette Voice...
TAKING TOO MUCH TIME TO OPEN. THE HARD DRIVE LAMP RUNNING CONTINUOUSLY
Hi!
Have you ever tried reinstalling windows xp before? if not then revert back to me. I'll teach you how to check if the system still has PC restore. If you ever have tried reinstalling windows or your hdd has been replaced, then you may need to reinstall windows manually by using the discs.
Hope this helps.
Karlox™
May 18, 2008 | Dell Inspiron 6000 Notebook
DVR to DVD Recorder
Hello Steve,
I know what you are asking for, and yes it can be done but not how you want to do it. The DVD recorder has coded into it software that prevents the DVD recorder from copying copywritten encrypted material (Video Cypher or Macrovision). What you need is another device to prevent the effects of the encryption (a company called SIMA makes devices that do this) the DVR would connect to the SIMA device and then to the DVD recorder.
I hope this helps,
Thank you,
Shuttle83
Oct 14, 2007 | Directv Plus DVR DTV Receiver / 100-Hours...
Olympus VN-4100PC  Digital Voice Recorder Logo
19 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
