Question about Lexmark C534N Printer
I'm having a faint shadow on each page on a Lexmark c534n
  • 1 more comment
  • gigshot Sep 14, 2010
    I don't know how to realign the heads. Bear in mind this is a lazer printer. I run it though the calibration cycle. I was able to print out help and they list 5 reasons:
    1. defective toner
    2. Transfer belt worn
    3. Photo conductor worn or defective
    4. Fuser warn or defective
    5. Toner is in the paper path
    What is interesting is that I have 2 of these and they are both doing it. This one only has 3000 prints on it. I have replaced the toner with refurbished toner. I'm wondering if that is the problem.
    From my memory, that is what happens to a ink jet. I have never seen that option on a lazer printer?
    I'm running a Mac...
  • 182 Answers
The most important thing that comes to mind is whether or not you have aligned the print heads cause this kind of problem is result of misalignment.
also after that try to calibrate the printer
This should resolve the problem else it could be a problem with laser scanning mirror assembly
Posted on Sep 14, 2010
  • 1 more comment
  • Goldi Kunal Sep 14, 2010
    exactly ..you got it..replacing the toner with refurbished toner is the reason.
    And regarding your about printhead alignment here you go...
    Whenever you install a printhead, the printer automatically prints a test page of alignment
    patterns. There are eight patterns: A, B, C, D, E, F, G, and H.
    Once the alignment page prints, the operator panel displays the current alignment value for
    each pattern.
    1 From the Test A alignment group on the test page, select the number under the
    alignment pattern that comes closest to forming a straight line.
    2 Press Menu> to scroll to the correct alignment value.
    3 Press Select.
    4 Repeat these steps for alignment groups B, C, D, E, F, G, and H.
    Once you select the value for alignment group H, the printer returns to Ready.
    Try the following steps:
    •1
    Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
    •2
    Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
    •3
    Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
    •4
    Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
    •5
    Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
    •6
    Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
    Other Options to Try
    •1
    Let the printer sit overnight after running the self-cleaning utility and then print something to see if your initial try with the self-cleaning utility just needed a few hours to work, as this is sometimes the case.
    •2
    Remove your printer cartridge. If your print heads are on your printer cartridge rather than inside your printer, soak your printer cartridge in hot water overnight. Dry it off the next morning, and then put it back in your printer and run the self-cleaning utility again.
    •3
    Remove your printer cartridge. If your print heads are inside your printer, take a Q-tip and dip it in warm water. Run the Q-tip over the print heads to loosen and remove any dried ink from them. Put the cartridge back, and run the self-cleaning utility again. This should unclog your print heads.
    •4
    Remove the printer cartridge. If your print heads are inside your printer, take an eyedropper and put 7 to 10 drops of isopropyl alcohol inside the area where the ink receptacle is and where the ink flows from the cartridge to the print heads. Wait overnight and then put the cartridge back in and run the self-cleaning utility again.
    •5
    Remove the printer cartridge. If your print heads are on your cartridge, spray a paper towel with a household cleaner and wipe it gently over the print heads on your cartridge. Pat the cartridge dry and then put the cartridge back in your printer and run the self-cleaning utility again
    If you are running Mac then you will hae to perform the same steps post going on to System Prefrences
I get a warning message that the transfer belt on my C534n needs replacing. The specification says 120,000 prints, I have just run the diagnostics report and have done 28,000 only! Any ideas?
If you only printed 28,000 pages on your Transfer Belt kit, this might be a pre-mature failure and it needs a replacement. Please contact our Technical Support Hotline.
Nov 12, 2012 | Lexmark 34a0050 - C534n Laser Printer
Black lines on side of page lexmark c534
Please try to print the menu settings page, if you're getting the black lines, replace the photoconductor for the black toner.
If you need further assistance please contact Lexmark Technical Support.
Oct 14, 2011 | Lexmark C534N Printer
I have a Lexmark C534n color printer error message comes up 120.10 service fuser error. What does this mean.?
It means there's an issue with the fuser, and the fuser likely needs service or replacement. I would not recommend doing this yourself if you haven't done this before, take it to a repair shop.
Feb 24, 2011 | Lexmark C534N Printer
I have replaced photoconductor in my lexmark c534 but it still saying its low
You must reset the supply counter after replacing any individual photoconductor unit. Visit the Lexmark website at http://bit.ly/dk8nHs for the instructions on how to reset the photoconductor page counter. Thanks.
Sep 27, 2010 | Lexmark C534N Printer
Lexmark c534n printer, warning for depleted color units do not go away after replacement
The supply counter must be reset manually after a photoconductor unit is replaced. Here's an article on How to Reset the Photo Conductor (PC) Page Count After Photo Conductor Unit Replacement on C52x and C53x Series Printers. Just click on this link: http://bit.ly/dk8nHs. Thank you for choosing Lexmark.
Jun 13, 2010 | Lexmark C534N Printer
The C534n says Cyan low (0%) was printing, now won't print.
If you're still going to print in colors, unfortunately, it won't print and there's no way for the printer to ignore your out of ink level unless you change the cyan ink. I understand how costly that can be but you can still make the printer print if you configure it for black-only printing. Here's a link to download the User's Guide for the instructions on how to configure printer for Color Lock Out Mode. http://www.lexmark.com/publications/pdfs/2007/c53x/en/ug.pdf . Scroll to Printing, page 50, for the instructions. Since you won't be printing in color, you have to remove the color supplies. The User's Guide will give you instructions for that as well.
Apr 11, 2010 | Lexmark C534N Printer
2 sided print on c534n
goes through below link and download the pdf file in page nuber 50 how to take duplex print....
www.bcplib.org/PDF/Manuals/Lexmark%20c530dn.pdf
Oct 26, 2009 | Lexmark C534N Printer
Wrong Media loaded error - tranceparencies
hi!!! in that kind of problem maybe the paper sensor was defective and it can't detect the kind of paper you loaded to your printer.
Apr 18, 2009 | Lexmark C534N Printer
Lexmark C534N Printer Logo
181 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
