Question about Maytag MDE9206 Dryer
Blew a fuse at the panel, repaired. heater stopped, continued to tumble now it won t start
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 14, 2010
I have a Bosch Nexxt 500 andjust replaced the heating element less than 6 months ago. A week ago it stopped heating up again. Took the back panel off, pushed the reset button but now when I turn it on, the...
Sounds like a bad thermal fuse or thermostat, check all of them with a multi meter for continuity. as for the heater going out I would check ur venting inside and out the machine. the fuses and heater blow out for a reason? Usually due to overheating issues? I suspect ur lint build up is the problem?
Aug 16, 2012 | Bosch Nexxt 500 Dryer
Heater coil works but has stopped tumbling. when the doors clsoing, the heater works.
Here is a tip that I wrote about why an electricdryer will not stop heating sometimes.
ElectricDryer won't stop heating
heatman101
Aug 01, 2011 | Whirlpool Dryers
My dryer does stoped and it does not start again
look for a blown DUCT FUSE
Failure to remove air restrictions will reult in continued problems. Tumble dryers have 2 small limits in the rear and another on the heater element. Tilt the dryer over and remove the base to clean out the fluff. American dryer repair photos HERE
Feb 16, 2010 | Dryers
My dryer will not start. i tried a new start switch, no change. the door switch is working. if the thermal fuse is shot will that stop the dryer from working or only stop the heater from working. the moter...
there is 2 thermal fuses on some models 1 for the heater and the other will keep the unit from coming on at all which is most likely your problem. Example on a series 90 kenmore there is a thermal fuse and high limit mounted right on the side of the heater element housing and another fuse and thermostat mounted on the blower housing. The fuse on the blower housing will kill dryer completely.
Jan 08, 2010 | Whirlpool Dryers
Dryer won't heat up but tumbles. What could be
you could have a bad heating element, a tripped circuit breaker, a blown fuse in the dryer or a bad timer. you can check the element and fuses/ thermostats with an ohm meter for continuity.
Sep 17, 2009 | Dryers
No heat on Indesit IS60V tumble dryer
The heater and stats are located at the rear of the m/c behind a removable panel.
you need a meter to test them, more likely to be a stat problem, but again you must test them for continuity.
Plz leave feed back for my solution.
Thanks.
Dec 14, 2008 | Indesit WA 115 Front Load Washer
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 21, 2008 | Miele Novotronic T220 Electric Dryer
Dryers Logo
56 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
