Question about Compaq Presario CQ60-220US PC Laptop
Ive had my laptop for only 13 months and it now has a black screen it has power but no picture and it was real hot especially on the bottom were the vent is.
  • 393 Answers
This problem from the bios ... u need to update the bios ... if know any one has bios copier u can download from the internet and update it... or check the way from updating bios from usb even if u system dose not show any thing...thanks
Posted on Sep 14, 2010
Help Black screen fan but no hdd light
No display and not booting after getting very hot is likely to be a GPU issue. This is repairable.
Jun 02, 2014 | HP Pavilion g7-1310us 17.3" Laptop
Hi, my screen in my laptop got 3 black hole can you please advise the real price of a screen. thx
This model can fix with your laptop model.
http://cgi.ebay.com/13-3-WXGA-GLOSSY-LED-LCD-B133EW06V-0-HW-1A-FW-1-/260776278475?pt=LH_DefaultDomain_0&hash=item3cb77a39cb
Jun 30, 2011 | NEC VERSA S3300 LAPTOP LCD SCREEN 13.3"...
My vizio p50hdm made a popping sound from the rear. Afterwards, the picture disappeared and tv screen was black (as if the power was off). Then within a minute the picture reappeared but looked real dull...
The z-sustain board is bad. One of the the heat sinks on the board is cool to the touch. These had LG circuit boards and the number on the sticker, on the board, was a good LG part number. The part numbers were 6871QZH044A.
Do a search on the internet with Google, Yahoo, or Ebay with this part number. The board unplugs and the new one plugs back up. Not an advanced technical repair. Unplug the set and take the back off and match the picture on Ebay with the one in your set. And especially match the part numer.
May 24, 2011 | V, Inc. Vizio P50HD Plasma Television
Rheem 40 gallon wh installed 12-13-06. Have
Was the tank full and all air out of lines before turning power onto it. If it's not full it will blow the new elements you just put in.
If the bottom one is good you get like luke warm then it will start cooling off.
If the top one is good it will be a burst of real hot then cold.
Dec 18, 2009 | Water Heaters
Akai LCT2721AD - Power on - Sound on - Black screen (No Picture)
Ive reviewed and assisted anoter person who had a similar problem that caused the tv to malfunctioin simialr to yours. After doing some short research and the other person who had the problem, came to find out that 4 resistors failed on the main board causing this to happen. It also could be the backlight of your Plasma screen tv, or your Plasma screen itself is shot.
I would recomened that if you have no active warenty to give a visual inspection of the Tv, via removing the rear black plastic pannel to see if any of the corisponding chips have any burn marks or excessive heat stress. these items seem to be failing about the 12 month mark
Good luck
May 12, 2008 | Akai LCT2721AD 27 in. LCD Television
Screen going black
Get a strong flashlight and shine in at at angle toward the screen.
If you can see the image, which you probably can, then your laptop's backlight is malfunctioning.
Since you've only had it for a month, check with the retailer or manufacturer to see if it is still under warranty. Hopefully it is and you can get it replaced.
But before you send it back, if it has a DVI, HDMI or VGA port on it (most likely it does, unless it's an ultra-slim model), connect a PC monitor to it and turn it on. You may have to press a certain key combination like Fn-F4 or Fn-F8 to switch between the laptop display and external display, but hopefully the screen will display on the external display.
From there you can use your laptop as necessary to back up any data that you need before you send it in for service.
Apr 07, 2008 | Acer Aspire 5610-4648 Notebook
Wont power up
Sounds like it is shutting down to 'protect' itself, because the thermal grease has dried out, and can no longer transfer heat correctly.
You will need to take it apart, and separate the heatsink from the cpu.
Clean both contact areas (the heatsink and the cpu) and apply new thermal grease.
Jan 15, 2008 | HP Pavilion dv6000z Notebook
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Compaq Presario CQ60-220US PC Laptop Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
