Question about Mitsubishi WD-62531 Projection Television
Were is the lamp cover of the mitsubishi WD-62531 at so i can change the lamp
    Scholar:
  • 62 Answers
It's on the back of the tv, located on the left while facing the back. There are 2 screws holding the lamp cover and 2 more holding the lamp.
Posted on Sep 22, 2010
Need a Mitsubishi WD-62531 Lamp. I have 2 part numbers which one is right?
go to www.shopjimmy.com
when you search brand and model it will appear..
Jun 07, 2012 | Mitsubishi WD-62531 Projection Television
I cannot find the model number on my televison
Look in the back cover the tv have a sticker, u will find the make and model of the tv.Take that number.Tries websites like Partstore.com,Ebay.com to buy the lamp for the tv.
Aug 02, 2010 | Mitsubishi WD-62531 Projection Television
WD-62531 fan
If the fans aren't operating then the set shouldn't stay on or even turn on. If its the main lamp exhaust fan then you are looking for part number 299P288010. They are relatively easy to replace as they only have a 3 pin connector that will plug into the main board or the power supply. Verify its that fan and as always if you replace it yourself make sure the set is unplugged. Once replaced the back will have to be re-installed or the set will not work as it has a safety switch that detects when the lamp door is off and on.
Jun 29, 2010 | Mitsubishi WD-62531 Projection Television
I have a 62 inch mitsuibishi dlp you hear the sound but the picture is off were can i buy a wd-62531 lamp cartridge
Hi
Thanks for using FixYa. You can buy the lamp from this link:
Mitsubishi wd-62531 Parts
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
RED LAMP LIGHT!!
Check to make sure your lamp is not blown.
Make sure you installed a Mits original, and not a generic.
Make sure the lamp is seated and secured properly, as slight movement can cause a loss of connection.
Slide your set out to the side and peer into it through the slats. Can you see the lamp fire on?
Your symptom does not indicate that it could be a problem other than the lamp and the installation thereof, however---there is an instance where 2 capacitors will blow on the power supply and cause a red lamp light to show. Furthermore, the light engine itself could be causing the problems.
But, since you just installed the lamp, I would look over your installation.
Apr 09, 2009 | Mitsubishi WD-62531 Projection Television
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Projection Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
