Question about Clark Forklift Horn Button Switch , Cat Etc
Cat E8000 throwing 05 code trips code whenyou step on accelerator no fwd and reverse
I have a frightliner 2007 century classic with c15 cat eng its throwing inatmitting eng open 128s290 05 please advise
Are you sure that is the code? Its engine "128", but the rest isnt adding up.
Here are the all the C15 engine codes.http://world-engine-blog.blogspot.com/2013/09/c13-c15-and-c18-engines-diagnostic_23.html ENGINES AND MORE
Apr 29, 2015 | RTO Ho Herpa Freightliner Truck Tractor
03 silverado no reverse has fwd.
that code has something to do with reverse its a tranny code
Jan 25, 2014 | Chevrolet Silverado 1500 Cars & Trucks
2004 SUZUKI VERONA THROWING P1902 MASS AIR FLOW
Check intake manifold vacuum with a vacuum gauge. Should be 17-21 inches. Low vacuum 10-15 inches would indicate a bad cat. Or you can remove the oxygen sensor and drive it. If the power is better you have a bad cat. Misfires can melt the cat converter.
Dec 19, 2013 | Cars & Trucks
05 caravan is it a p4044 code
the code p 4044 refers to exhaust gas recirculation range /performance--reading above or below the specified range
could be a problem valve or solenoid or wiring
the remark about the cat converter is valid as it indicates that when under load the cat converter is blocking the exhaust
this occurs when the honeycomb internals cracks and the bits block the exhaust exit under high gas flows ( from your use description)
you can get replacement cat converters that use flange fittings and they are therefore cheaper when needing replacing
cat converters crack when running hot and are then immersed in extreme cold ( snow , running ice water)when driving
Jun 01, 2017 | Dodge Grand Caravan Cars & Trucks
2003 Dodge Grand Caravan Sport FWD. Acceleration and braking
if any thing the calipers could be sticking but the ratcheting noise in reverse is normal
Aug 06, 2009 | 2003 Dodge Grand Caravan AWD
O2 sensor trouble code
420 and 136 codes are O2 sensors. 420 is the downstream (aft of converter) should be sending a constant reading. 136 is the up-stream and should be sending a flux reading.
May 11, 2009 | Pontiac Vibe Cars & Trucks
96 gmc sonoma will not accelerate over 30 mph
it very well could be the cat usually that can make the vehicles computer throw the wrong code
Dec 27, 2008 | 1996 GMC Sonoma
Clark Forklift Horn Button Switch  , Cat Etc Logo
51 people viewed this question
Top Clark Electrical Supplies Experts
Wayne Fellows
Wayne Fellows
Bill Boyd
Are you a Clark Electrical Supply Expert? Answer questions, earn points and help others
