Question about Quantaray 28-200mm f/3.8-5.6 for Canon AF
Accesories y need to buy a cover and len hood Where I buy this accesories
How do you replace the headlight on a 2002 Daewoo Lanos
Hi there, together with providing you the solution to the problem, I also took the liberty of going one step further in giving you steps on how to remove the headlight bulb.
  • Find the hood release handle and activate it, the hood should pop open.
  • Once the hood is popped open locate the hood secondary or safety latch and release it. Then finish opening the hood.
  • Locate and remove mounting clips for any plastic shields that cover the headlight lens mounting screws or clips.
  • Some headlight bulbs can be replaced by simply grasping the bulb socket behind the headlight lens and turn it counter clockwise to remove it. This will expose the headlight bulb.
  • If the headlight bulb socket is not accessible the headlight lens may need to be remove or obstructions behind the bulb removed to gain access to the headlight bulb socket.
  • To remove the headlight lens remove all mounting screws and clips that hold the headlight lens in place.
  • After the headlight housing has been removed from it's mounts, release the headlight bulb from the headlight lens housing (turn counter clockwise) the bulb will then come out of the headlight assembly. Once removed, visually verify that the replacement bulb is exactly the same as the failed bulb before to ensure a proper repair.
  • Clean the headlight lens free from all debris to help maintain the seal from the bulb to the lens. This will keep moisture out of the lens.
  • Install the new headlight bulb by turning the retainer ring or bulb clockwise.
  • Re-install the headlight lens housing and reinstall electrical connector.
  • Re-install plastic covers.
After the job is complete turn the ignition key to the "on" position and activate the headlight switch. Observe the newly replaced headlight bulb to ensure proper operation.
Glad to be of help!!!
Jan 21, 2011 | 2002 Daewoo Lanos
Looking for lens hood
Local camera "shows" might be a good place for you to look - the glass is sold by RITZ so you could check with them - also I am a firm believer in buying the manufacturers own glass - it costs more but you will always be able to get accessories for the glass and in most cases the glass is much better quality. I recognize for some this is no issue but if you ever need to resell you equipment - something I do ever 18 months - you will find the aftermarket glass - tamaron, tokina - vivitar - and quantaray all suffer major hits because they are less expensive alternatives to factory glass...
Apr 27, 2010 | Quantaray 18200mm f3563 DC Lens
NEED 1999 olds intrigue serpentine belt diagram
1999 OLDSMOBILE INTRIGUE - V6 3.5L 214ci GAS FI N H
Belt Routing Diagram - Multiple Accesory
1999 OLDSMOBILE INTRIGUE - V6 3.8L 231ci GAS FI N K
I hope helps with this (remember rated this help) Good luck.
Dec 23, 2009 | 1999 Oldsmobile Intrigue
NEC GT6000 LCD PROJECTOR
check the lens cover hood to see that it's on correctly, and that the lamp door is closed. if they are, check the switches. on the hood and the lamp door, there are plastic protrusions that hit the switch activators. if they are broken off or warped, you need to replace the door/hood. if they are there, check the switch itself. replace as necessary.
Nov 17, 2009 | NEC GT6000 Multimedia Projector
I don't know how to take off the head light lens cover on my nissan maxiuma
Probably not a lens cover at all. It's just a 1 piece plastic headlight. It you are wanting to replace a bulb , they go in from the back . Open the hood and you should be able to see where the wires to the bulb go in the back of the headlight.
Nov 06, 2009 | 1997 Nissan Maxima
Need new fresnel lens for vivitar 285
Cheapest solution is insert accesory 28 mm Diffuser in its slot(in the front of Tube).
Or buy defected Flash from ebay for this part.
Oct 27, 2009 | Vivitar 285HV Flash
Just bought a 52mm hood, but it doesn't fit... Why??! Do I need another adapter?
The hood you buy needs to be the same as the inner ring on your lens. If you look at the inside of the lens ring or on the outside of the lens it will tell you what size filters will fit your lens. If the 52mm is too small or too big you should be able to find a adapter for it so it will fit. Try going to B&H photo website. They have tons of photography items. Hope this helps.
Oct 27, 2009 | Kodak EasyShare Z710 Digital Camera
Hi, Own an Olympus 35sp camera. Need to buy a 49mm lens hood for same. Live in Ireland. Any suggested outlets. Many thanks.
I am in the US, But I believe the UK based Jessops camera shops should have a 49mm lens hood to fit it. I would just get a collapsible rubber one. They are fairly cheap and just screw in the filter threads. fold them back when not in use, and you can still mount your lens cap.
You might also try Ebay. Shipping from the UK to you should be minimal, but some asian dealers offer very good bargains in those kinds of goods too.
lightspiritphotography.com
Oct 24, 2009 | Photography
Quantaray 28-200mm f/3.8-5.6 for Canon AF Logo
Top Quantaray Cameras Experts
Steve
Doberman
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
