Question about HP Office Equipment & Supplies
My HP Photosmart 3210 is not printing the entire page. I have attempted to do an alignment and I'm being told to consult my owners manual, which I do not have. Is there a simple way to reslove this problem?
  • HP Expert
  • 2,973 Answers
Please un and re install the drivers for the device following the link below verbatim.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Posted on Sep 14, 2010
It is only printing blue
Please, try the steps given in section named "printing issues" in Hp Photosmart 3210 Manual, If this does not resolve your issue, then the printer will need to be serviced/or replaced. Please contact HP, phone support for further assistance. https://guideusermanual.com/product-name-photosmart-3210-all-in-one-printer-manual&po=317310&lang=English
May 19, 2016 | HP Photosmart 3210 Printer
My HP Photosmart 3210 Printer does not Print Red.
WELL IT'S 5 DEC 2012, THIS HP 3210 QUIT MAGENTA'S.
WENT TO TOOLS TO CHECK LEVELS, NO YELLOW, GOT NEW CARTRIDGE, TEST SHOWED NO MAGENTA'S. REMOVED RIGHT SIDE COVER (GENTLY) AND REMOVED ALL TEN CABLES AND REINSERTED CAREFULLY. TESTED AGAIN, AND HAD LINES ONLY ON BOTH LIGHT AND DARK MAGENTA'S,
RAN CLEAN HEADS, SIX TIMES AND ALIGN PRINTER ONCE.
PICTURE GOT BETTER AND BETTER FINAL TEST DIAGNOSTIC PAGE PERFECT ALL SOLIDS. GOOD LUCK KEEP GOING
Jun 08, 2012 | HP Photosmart 3210 Printer
Will not proceed with reallignment--says to insert paper and press ok but then it doesn't do it.
This device having auto alignment Technic,If print heads are clogged it will not print align page properly result alignment will not completed. In this condition it will ask for align print heads when ever printer switched on. To over come from this situation clean print heads fist, manually or though tool box, then try for align. If printer heads are out of health condition replace faulty print heads then perform align process.
Oct 27, 2011 | HP Photosmart 3210 Printer
I have a hp photosmart 3210 all-in-one and it keeps printing the same thing over and over as soon as you turn it on
It can happen due to different causes:
If the cartridges are new, the automatic alignment process is not complete, for that:
1.Turn off the printer and turn it on again
2.Let the printer print the allignment page
3.After printing the alignment page, disconnect the USB cable which is connected behind the printer
4.Place the allignment sheet inside the scanner glass and press the scan button on the printer
The alignment is complete when the printed page is scanned
Turn off the printer and turn it on again, it should be fixed
The other possible causes might be:
The cartridges are not correctly installed or one of the cartridges is defective.
In that case reinstall the cartridges after cleaning them with lint free soft cloth.
If that does not work, then at least one of the cartridges need to be replaced
Apr 24, 2011 | HP Photosmart 3210 Printer
I have a HP 3210 All-in-one printer that I am having problems with. Whenever I print a picture or anything is certain colors I get stripes. It works fine in black and white. I have replaced all of the ink...
the nozzles are clogged most likely. try to clean it by using the software provided. another thing is try to align the print heads. that's also included in the software for the printer.
Jun 25, 2010 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Oct 07, 2009 | HP Photosmart 3210 Printer
Photosmart 3210 - A Printer alignment failed error
Mine has done the same thing.
To fix this you have to reinstall the software, then reboot your computer.
I did that, and the printer alignment function worked fine for a while, then I started getting the same problem again, possibly after I had installed other software not related to the printer -- I don't really know.
In any event, it's doing the same thing again, so I just "cancel" the alignment and continue to use the printer. My prints are fine.
Jul 20, 2009 | HP Photosmart 3210 Printer
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
