Question about Car Audio & Video
Nitro BMW 484 roofers stopped playing
I have a Nitro BMW 484 amp. The subwoofers stopped playing and when I checked it, I notice the led indicator light on the amp turn red from green. What is the causing the problem and how can I fix the problem. In other words, what should I do to turn the Indicator light back to green so that it can play again. I've tried to locate an instruction manual on the net, but to no avail. Any assistance will be highly appreciated.
Thanks.
MG
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Posted on May 15, 2008
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
I have a nitro 1200 watt amp earlier today it was workin with no problems we parked then came back in the car 3 hours later and it wasnt workin wont come on or anything just red light which is protecting...
Check your speaker wires, make sure everythings connected right with no short circuits, and check all of the fuses in the amp, and make sure none of them are blown. If all this checks out just check the battery wire, grnd, and remote wires. It has to be a wiring issue unless you busted your amp, but if was working when you tuned it off it should be alright... hop this helps...
Sep 10, 2009 | Nitro BMW-484 Car Amp
BMW 318i oil
Around 4 litres.
Thanks.
Aug 06, 2009 | Nitro BMW-484 Car Amp
Nito bmw 484
HI FREN UR AMPLIFIER DONT HAVE POWER TO PUSH BOTH OF UR .. DOUBLE VOICE COIL SUBWOOFER,, TRY USING SINGLE SUB AND TRY ... IF U HAVE SAME PROBLEM ... USE CAPACITOR ,,,
Apr 02, 2009 | Nitro BMW-482 Car Audio Amplifier
Nitro BMW 484 1200 watt amp.
check fuses and remote wire at the head unit. must have a good ground at amp.
Dec 03, 2008 | Nitro BMW-482 Car Audio Amplifier
Nitro BMW 1000w amp not working
if AMP turns on and no sound , check the inernal fuses that protect the output from overload , in most cases this fuses act like a cicuit breaker , they set back on again in a few seconds. hope this helps
Apr 28, 2008 | Nitro BMW-481 Car Audio Amplifier
No Power :( NEED HELP
Check the connection with the subs. See if all wires are connected or check for any break in the wire. Also make sure that the RCA's are connected to the subwoofer output at the back of your deck. Also check setting on your AMP.
Nov 30, 2007 | Nitro BMW-481 Car Audio Amplifier
Car Audio & Video Logo
185 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
