Question about Maytag MAH2400A Compact Front Load Washer
My maytag front load washer stopped working inthe middle of the cycle and flashed E3 on the screen now it won't rinse or spin
  • 2 more comments
  • Kymburton88 Sep 14, 2010
    Already read the information I received for free somewhere else on the Internet. The drum is fine and moves freely all wires seem to be connected as well.
    Yes, the manual is available online. I read the exact same thing word for word. As I said the drum moves fine and all wires seem to be connected just fine. Nothing loose. Any other suggestions for the problem? It's not draining or spinning
    Discovered feom the wire connection harness that it looks brownish on one part. Possibly burnt? Could this have some effect on the motor?
    So If the wire connection harness is burnt how could this have happened and what would I so to fix it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. There are many causes of Error E3 codes---
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case or “Suds” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
3. A poor connection – Check wire harness connector to motor. Unplug connector and pull on each wire. If a wire connector comes loose from the plug, bend locking tab up as illustrated.
NOTE: If a locking tab is not properly seated in the plug connector, the terminals will not fully engage as the connector is plugged into the Motor Terminal Block. Inspect the terminals on the motor side of the connector. Straighten any bent terminals if they exist. Recheck the harness side of the terminal block if any bent terminals are found. Bent terminals can indicate a problem with the locking tab inside the plug. Reconnect harness plug to Motor Terminal Block. Run washer through a quick service cycle (wash and spin) to check motor operation. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 14, 2010
  • 1 more comment
  • Rylee Smith
    Rylee Smith Sep 14, 2010
    Dont think its available on internet somewhere as I checked it in its service manual and then provided you this information.
  • Rylee Smith
    Yup right this can affect the motor from not working correctly, please check #3 in the previous post.
  • Rylee Smith
    Replace the wire harness and check the terminal block.
Why slow spinning?
a slow spin sometimes indicates that a out of balance switch might be malfunctioning
Oct 17, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Got the E3 code, replaced the board. The new board won' even fire up. Thoughts?
Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Jan 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
At the middle of my load there was stop with code symbol E3
E3 is that the machine can't see that the motor is spinning. Could either be a loose connector at the motor or a loose hall-effect sensor. this might be a fairly easy fix for a repair tech,
Dec 27, 2009 | Maytag MAH8700A Front Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Frontload washer will not complete a load..shows E3 on display
e3 is a motor sensor not reading the motor properly un plug the unit for 5min and try it that will clear it but you may need a new sensor check the connectors at the motor sensor
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag may8700aww washer with e3 code
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
May 05, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH2400A Compact Front Load Washer Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
