Don't get any video output from the onboard video card
  • 3 more comments
  • daryllow43 Sep 14, 2010
    i'm trying to get my gateway 'e-4500d' working, it powers on, but my monitor does not respond to it, it had a sticker over the monitor port that says: use alternate monitor port. but the port that it's referring to is not present on the cpu, and i guess when they built it they disabled the onboard monitor port. please help i'm out of options
    i've took my pci video card out of my other pc, and it still doesn't get any video, but it works in my old pc
    this is a desktop tower, not a laptop, i know the monitor is good because it works with my old pc, and i also took the video card out of my working pc and put it in it and still no video i don't understand.
    i doubt it, because i never installed any drivers for it on my old pc, but if i did need a driver installed i wouldn't be able to if i don't have any video to begin with to see what i'm doing
    this computer use to belong to a college, and it has 2 pci slots, and 1 brown slot (i don't know what it's called) which they were using as a monitor port, the reason i know this is because the opening to that slot is open like something was there before, and there was a label on the onboard monitor port saying: 'do not use this port, use the alternate monitor port', which is missing from that unknown slot on the mother board. maybe this will help you figure it out.
    President:
  • 4,070 Answers
Hi! Are you working on this? The video card could be faulty and will need replacement.
Posted on Sep 14, 2010
  • dj_relly999
    dj_relly999 Sep 14, 2010
    The socket where the video card is inserted could be dirty. Try blowing compressed air to create contact to the video card and try cleanin the copper contact of the video card with an eraser till it clears out the dirt. Try this and see how it goes.
  • 2,973 Answers
Please go to Start ->Control Panel->System->HW->Device Manager. Here in the Display Adapters select the adapter and delete/remove it. Reboot and reach here again. Now from the menu select Scan for new HW from Actions. The Windows will automatically load the required drivers for the onboard display adapter.
  • Rinoo Kumari Sep 14, 2010
    I am sure that it mayhave the option to use an external monitor. That seems to be the only way out if the onboard port has been disabled.
    Does the video card need any drivers to be installed?
Install new video card in Gateway GM5072 with Pheonix bios and disable oonboard video
There should be an option to disable the onboard VGA connection within the BIOS of the computer.
Plug your monitor into the onboard video output to do this.
Dec 24, 2011 | Gateway GT5220 PC Desktop
Installed GEForce NVidia 8400GS graphic card but no video output. Onboard and other video cards will work. The 8400GS will work in other desktops correctly. Any help would be graet!
Assuming that you have installed the drivers for your new board, go into Control Panel, select Device manager and Display Adapters.
Dissable the onboard adapter and enable the NVidia card.
Dec 27, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
No video in onboard plugin
If the motherboard has an onboard VGA output - try that. But first remove the plugin video card from the computer and then check the onboard VGA output.
Nov 02, 2010 | MSI 7207-090(K8NGM2-NBP) Socket...
Im trying to install my ATI Radeon 9250 265mb graphics card and I have installed the Catalyst control center but when i turn off my computer and unplug my machine and put in the graphic card (PCI) And boot...
There may be a setting in your BIOS for your video output.
If you were originally using the onboard VGA video output, there may be an option in the BIOS to switch to PCI output.
Jul 11, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
No display but power led is on
sounds like a video card problem in your pc. If you are using the onboard video output on your motherboard, you probably need a new one. If you are using a card that has been added to the board in a slot, try your onboard output (looks the same)
Jun 15, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
PCI Express slot not working
go into the bios and change the video settings from onboard video to pcie video
Mar 27, 2009 | Gateway GT5082 PC Desktop
Onboard video has failed..how do I change in bios to video card ?
first install the video card in the pci slot first so that you have access to your monitors screen for you to disable the on board video chip or video card, go to the CMOS setup by pressing del key. once there you can browse through the CMOS setup to disable the on board video chip.
Dec 22, 2008 | Gateway GM5088 PC Desktop
Video card not working, monitor goes off
     In the bios there could be setting to disable your onboard video. Since the output was broken, see if there is an option to disable the onboard setting. If you do this and you are still having problems, I would go ahead and start in safe mode, then lower your resulution to the lowest settings till you can get the video drivers loaded for the new card that you have just bought.
        Joe < Data Miner >
Oct 31, 2008 | Dell Dimension 3000 PC Desktop
No video output
try this -remove the card then restart the pc (if this is xp) start/right click my computer/properties/device manger-look for "display adapters" find the onboard type you have and uninstall it power off then install the new card you might have to look in device manager for something referred to as graphics controller
Oct 05, 2007 | ASUS P5VD2-MX SE Motherboard
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
