Question about Black & Decker D2030 Iron
How do you disassemble iron ? i need to repair a loose connection
Shark iron leaks water from the bottom of the body where the power cord come out. could it be a crack in the holding tank? Is there a way to fix it,or will I need to purchase a new iron?
It is hard to assess what would be the cause, but I think your diagnosis may be correct, of a possible crack, or a tube has come loose. You tube has instructions on how to disassemble and iron if you are up to it and have the tools. Then you'd have to order a replacement part, and re-assemble. I'd just go to walmart & buy a new iron! But that's me! :)
Iron Disassembly Process
Nov 16, 2016 | Irons
I plug iron red light stays lit but sole plate dont get hot
The connection to the resistance might be burned out. disassemble carully, might need soldering.
If you disassemble and don't have experience repairing an iron, take photos for each step. See some videos about iron repairing
Iron Repair No Power or Short in cord wire Rowenta Master
How to repair broken iron
Iron Repairing sajid salman flv
Oct 26, 2015 | Irons
The electrical connection 0n Rowenta steam iron DG5030 is inconsistent. I wish to disassemble and check the tightness of connection
Screws may hold the shell together but the halves are usually clipped together by hooks around the edge of the shell to discourage would be 'electricians' from doing home repairs. Once you've removed the screws and the body held by the screws doesn't come apart, look for a point where you can insert a screw driver in it to pry the body part out. If you can't do that, then don't do it. best thing to do is take it to a repair agent. At least it's safer.
Dec 28, 2014 | Rowenta Irons
Bosch iron TDA76 light comes, on no heat
Hello, welcome to Fixya!
The problem is either from the heating element or a disconnected/loosed wire.
Get a screw driver disassemble the iron and check for any visible wire disconnection or burn. If all wire connection in the iron are intact, then it means the heating element of the iron is defective and needs to be replaced.
Good luck.
Nov 04, 2011 | Irons
Light comes on but no heat
Good luck.
The electrical cord seems to have come loose near the iron itself causing the iron to shut off. is this a known problem & how do you fix it?
This has been happening since the first cord was attached to the first electric iron. The cord takes a beating. You will have to disassemble the handle and fix it ... or get a replacement.
Oct 06, 2010 | Sunbeam 6062 Iron with Auto Shutoff
Not heating up, flashing light
It sounds like you have a loose wire, check your plug to make sure the wire connections are sound. The loose connection may be where the wire enters the iron its self. For saftey I would have this repaired by a professional or have it replaced.
Dec 04, 2009 | Tefal Irons
MY ROWENTA IRONING CORD GETS HOT
This is probably caused by a connection inside the iron which is arcing. Should be disassembled and all connections inspected for heat damage. Repair connections as appropriate.
Charlie
Aug 20, 2009 | Rowenta DG-920 Iron
New face plate
Google California Electric Service in California, they are on Burnett Ave. Sorry I am having problems posting solution with my ISP connection.
Aug 04, 2008 | Rowenta DG-980 Iron
Black & Decker D2030 Iron Logo
208 people viewed this question
Top Black & Decker Irons Experts
tfelton3
nmccully
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
