Question about Toro Lawnmower 20099 Mower Mowers Lawn
My yardman Lawn mower does not restart after stopping to empy the bag. I have to put it down for about half to one hour and try again. The spark plug has been changed, the gas tank has been changed, the gas tank cover and it has been serviced.
    President:
  • 1,851 Answers
Try adjusting the magnito. AND - - try removing the screw that holds the bowl on the carb- - look for tiny holes in the bolt or screw - [ call it either] - then run a tiny wire in the holes and blow them out - blow hard -- then replace it. Be sure the o ring is on correctly too.
Posted on Sep 14, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 338 Answers
Adjusting the magneto or coil attached to the spark plug wire is a good idea but they tend to fail rather than go out of adjustment. You can purchase a spark tester at a dealer like www.arcolawn.com and adjust the tester to 12,000 volts. If the ignition coil will not jumt the gap replace the coil. They are about $75 and will fix your issue.Best wishes
Joewww.barter-joes.com
Posted on May 19, 2011
The engine stops after a half hour of mowing and will not start until it cools down, after which the cycle repeats itself
engine getting hot. Take rope pull off and clean off all the air fins on the cylinder block, use air how and do a good cleaning. If flywheel still have all the cooling fins it should help the problem or even solve it. Keep mower airways clean.
Jun 05, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Mtd yardman differential
check your drive belts, pulley's and belt tensioner... you could of gotten better help if you would of included the model #
Dec 03, 2013 | Mtd Garden
Obvious solutions won't start Lawn Mower!!!
Sounds like it's a fuel issue.
After the Carb rebuild, you put gas in the tank and started it up immediately. and ran it only 30 seconds.
If you look at the gas tank now, is it empty? Is there gas flowing out by the air filter? You sounds mechanically smart, just wondering if you messed up something with the carb rebuild and gas is flooding up into the carb. Check the Oil again, is it overfull from gas getting into the oil?
Jul 27, 2013 | Briggs & Stratton Garden
My yardman 6.5 intek seizes nup after i put the spark plug back in. i can un seize it when i take the plug out.
Hi, check that the engine has oil to the full mark on the dipstick. Regards Phil.
Aug 01, 2012 | Garden
Electric lawn mower slowed down then stopped working?
The carbon brushes on your mower have worn and, need to be replaced; order them from black & decker
May 21, 2009 | Black & Decker 19" Electric Lawnhog...
Toro Lawnmower 20099 Mower Mowers Lawn Logo
227 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
