Question about Refrigerators
Water shoots out of the water filter housing when you try to get water out of door
  • 96 Answers
The housing probably has a crack in it. If thats not the problem check the seal where the cap screws in. If thats fine check the cap itself for cracks. Please rate if this is helpfull
Posted on Sep 13, 2010
  • 3 more comments
  • baoujessy Oct 06, 2010
    there is no crack in the housing , the water shoots out the white cap that's on the top part of the whole thing.
  • Matt Oct 06, 2010
    Is the fridge still making ice? And when you try to get water does it still come out of the dispencer.
  • baoujessy Oct 07, 2010
    NO IT'S NOT MAKING ICE AND YES WATER COMES OUT OF THE DISPENCER BUT THE FLOW IS SLOW, NOT AS IT WAS BEFORE, i'VE TRIED EVERYTHING , IT'S DRIVING NUTS!
  • Matt Oct 07, 2010
    Ok you either have a hose off or it's split. Looking at the back of the fridge you should see plastic hoses. Be sure to check that all hoses are connected to the fittings. Just push the hoses into their fittings, after you do that have someone try to get water and look closely at all the hoses and fittings. You should be able to identify the problem then.
  • baoujessy Oct 19, 2010
    i did check that all the hoses are in the fittings but when you push 4 water, there is a blue hose in the back of the fridge and nothing goes through i. I even unscrewed the back low part and checked the fittings of the hoses in there, they are all in place. what do u think i should do next?
I need a filter bypass cap for model RF323TEDBSR
That model does not take a bypass plug if you don't have water coming. Thru the filter housing is bad part number (da97_08006g) and needs to be replaced but you could take it apart you could coupler the water lines and bypass the filter housing also called filter case
Mar 24, 2016 | Samsung Refrigerators
If filter needs replaced, would that prevent water flow to door and ice maker
The filter is just about the only thing that can keep water from getting to the icemaker and water dispenser. It would be very rare for the water valve to cause this. I have had clogged filters and no water will come out. Try removing the filter shake the water out and put it back in. Sometimes water will shoot out for a moment. This will give you the confirmation that the filter is the problem.
Jun 26, 2014 | Whirlpool Refrigerators
How do you change the water filter on Maytag MF12568AES?
Check top right inside of frig. Filer is inside the housing; open door turn filter counter-clockwise, the housing should allow you to lower filter to change it out. Place new filter, turn clockwise, push back into place and close door.
Apr 19, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
I have a refrigerator model #GD5PHAXMS10 icemaker that stopped working about two and a half weeks ago. At that time the water the water works dispenser worked like normal. Today the water dispenser...
The first thing to do if you already haven't is replace the filter,it's in the grill/kickplate below the freezer door. If you have relpaced filter,need to pull refrig from wall and check that their is good water pressure from house plumbing,if it is good the water valve the sends water to icemaker&door dispenser when water is called for is going to be the problem.The part # for that valve is 4389177 it could be purchased at your local appliance parts store on oline at;
searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
The filter BUT NOT the water valve could be purchased locally at Sears,Lowe's or Home Depot
I hope this helps you to diagnose your icemaker/dispenser
Gene
Aug 07, 2011 | Refrigerators
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
Water filter compartment leaking
If you have already replaced the filter and you can see the housing is still leaking, You have to replace the housing and water tank as an assembly (12956202). Make sure you verify it's the filter housing leaking, and not a fitting at the water valve which is right behind the plastic cover around and below the filter housing.
Apr 28, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Auto Water Dispenser
that maachine shoulnt work with out the filter inplace, all i can suggest is replacing the filter.
Mar 18, 2008 | Frigidaire FRS3R5EMB Side by Side...
How do you changing the water fileter
  • in case you haven't figured it out by now. open rt side door and top right corner is the filter push the little plastic tab and the housing drops down , a quarter turn counter clockwise and the filter should pull out, reinsert the new filter screwing clockwise and close housing, remember to pull water from dispenser right away you will have let air into system so some sputtering will occur till its purged
Feb 18, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Water leaking at filter
have you tryed replaceing the the filter .. look close at gasket and where gaset seals see if clean
Sep 01, 2007 | GE GSH25KGR Side by Side Refrigerator
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
