9/13/10- Our air conditioner makes a loud noise every time it goes on-enough to keep us awake at night. We have had your representatives in to look at it as well as the people who installed the system in 2006. There seems to be a conflict of opinions. One says I need a compressor, the other says I don't. They also suggested that I wait until the compressor dies to do something. In the meantime, no one has done anything or offered a solution for months now. If they keep me waiting long enough, my warranty will lapse something I'm sure they would be very pleased to have happen.I can't get a straight answer from these "experts"- perhaps you can help?
  • 455 Answers
Hello They sell a compressor blanket/jacket that will insluate/dampen compressor noise.It might help.
Posted on Sep 14, 2010
Humming noise in house
Might be a noisy draft inducer motor. Try backing out the bolts and repositioning it is what I would try. Or pay a dude $400 for a new one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 30, 2013 | Dryers
I have a screeching noise when I start my air conditioning.
It could be but how easy was the belt tensioner ? that may be the problem by not putting enough tension on the belt. How tight is the belt ?
May 19, 2012 | Cars & Trucks
My new Goodman central A/C unit makes a loud swishing noise in the attic( like a gust of wind). It this normal can anything be done to quiten it, and is this normal? It keeps us awake at night.
You can pick up some soundproofing material from Home Depot et al that will quiet it down a little bit, or you might be able to turn down the fan speed using your thermostat (if your t-stat supports this), but it is most likely a side-effect of your unit kicking on. You might have too big of a unit for your house, or too big of a blower. A service tech would be able to tell you if this was the case, but obviously that's going to cost a bit for them to come out and look at it.
Are you hearing the whooshing noise through your vents in your floor/wall/ceiling, or is it coming straight out of the attic? Depending on your air handler/thermostat, you might be able to set your fan to slowly spin up, rather than going to top speed right away. This would probably make it a little quieter for you. I wouldn't suggest trying to do it on your own however, because (again, depending on your unit) there could be some reason why it does it like this, and/or could be some settings that would be devastating if they were messed with. I would suggest you call in a service tech, unfortunately.
Aug 22, 2011 | Goodman CLQ36AR49 Air Conditioner
My air conditioner is making a noise and leaking!
mcdevito75 here, Have your A/C looked at by your local A/C repair shop. Sounds like the compressor is makeing the noise (expensive repair if so)
Jun 22, 2010 | Goldstar KG6000R Window Air Conditioner
Kenmore 76081 cycling rapidly
check voltage when it shuts down possible motor overheating
Mar 09, 2017 | Kenmore 76081 Wall/Window Air Conditioner
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
Unit constantly makes a clicking noise.
Electronic filters use static dicharges to filter the air. Unfortunately the make that clicking noise when they discharge. LG calls it a plasma filter. Clean both the regular and the plasma filter to see if that helps.
Dec 30, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Random "Cracking" Noise
Its refrigerant gas has leaked out so ice is forming on the evaporator which breaks and causes this cracking sound. The same is resulting in less cooling as well. Get the refrigerant gas pressure checked and fixed.
Jul 15, 2008 | Maytag Chassis Built-In Air Conditioner...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
