No display, all leds flashing - Computers & Internet
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Flashing freezer led
a flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
Nov 02, 2013 | Samsung RS2630SH Side by Side Refrigerator
Dishwasher won't start, turns on but no display
1: Defective door lock switch
2: Defective electronic control board.
Get model and serial number of machine, enter model number on search engine and seek same like conditions. You should find solution to problem, or place model number here for me to correctly tell what is wrong.
Oct 01, 2009 | Dishwashers
Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Jul 28, 2009 | Panasonic KX TG5100M Cordless Phone
Beko Wma 765 - spin select led flashing - unable to select progra
Hi I have the same problem and am waiting to see if anyone can help too, thansk xx
Jul 10, 2009 | Washing Machines
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
Audi A4 (2002) concert CD/Radio - all LED flashing radomly
Pulled out unit and found 5p inside - off to the professionals to be repaired!
Jan 25, 2009 | 2000 Audi A4
Led flashes on then off
did you find out what this problem was?
Dec 07, 2006 | Hotpoint Aquarius WF000 Front Load Washer
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
