Looking for a White-Westinghouse Washer/Dryer Manual For Model #: WLC275ES0
3 Suggested Answers
  • 6277 Answers
SOURCE: how do u replace broken
If yours is a 'standard' front loader (you do not say the actual model number) the belt should be easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 15, 2011
SOURCE: user manual for a White
http://www.appliance365.co.uk/userfiles/file/MDA/Laundry/WM603%20&%20WM602%20manual.pdf
Posted on May 18, 2011
Where can I find the manual for WHITE WESTINGHOUSE model WW105. Thanks in advance.
Options I can think of:
1. Contact your local Westinghouse reseller, and ask them to purchase it
2. Contact Westinghouse directly http://westinghouse.com/customer-care/
3. Use their troubleshooter here http://www.westinghouse.co.nz/Troubleshooter
May 08, 2014 | Washing Machines
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
White Westinghouse model #MWX413REW The
Belts can wear out from: Overloading, old age, or stretching. Sounds like a new belt is in order for you.
To see the specifications and schematics for this machine, and how many belts it has, type your model number into the web-site "SearsPartsDirect" when you are asked to .
God bless your efforts.
Dec 21, 2017 | Westinghouse WWS833ES Super Capacity Top...
LOUD HUM NOISE
check bearings or shock absorber.
Feb 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Removing agitator
Sorry, I can't help you. This is the area for asking questions about computer monitors, not washing machines. You clicked the wrong link.
Look at the top of the page, click the Westinghouse link and then on washing machine. Enter your question there.
Mar 28, 2008 | Westinghouse L1975NW Monitor
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
