Question about Mitsubishi WS-55511 55" Rear Projection Television
I have a Mitsubishi WS--55857 projection tv. When I push and hold the input and menu buttons I get 2 flashes pause 2 flashes pause 2 flashes. What do I needt to do to solve my problem? Thanks for any help you can give.
  • 2 more comments
  • lparaclete Sep 14, 2010
    Where do i find the Pico fuses and or how do i correct the bad convergence ICs. I have the back off but I'm a novice at this stuff. Thanks
    Where do i find the pico fuses on the tv and how do i know if it is a bad convergence IC. I'm a novice at this stuff.
    So you think if I buy the convergence repair kit it should solve my problem. Now when I try to turn the tv on the light on the switch stays lit for about 1-2 seconds and goes off. When I did push the menu and input buttons and hold it did flash 22 pause 22 pause etc. Thanks for your help.
    One last question and I won't bother you any more. Will I have to remove the circuit board from the TV to unsolder and remove the various fuses/capacitors from the board and solder in the new ones or can this be done with the board still in the TV. To me it looks like the board will need to be removed to replace the various items. Is this very difficult to do and is it likely to cause other problems? Thanks much for your help. My wife is currently physically disabled and I'm trying to get the TV fixed for her with minimal cost if possible.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code 2-2 means short protect which is either caused by bad convergence ICs and/or 2 Pico fuses (F9A05 and F9A04). You’ll need to open the back of the unit and replace the parts that have gone bad to resolve this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
  • 3 more comments
  • Rylee Smith
    Rylee Smith Sep 14, 2010
    Thanks for your reply, you can buy repair kits from this link and fix the issue yourself, if you know how to solder components.
  • Rylee Smith
    From what you have described it is the convergence ICs that are bad, and the pico fuses are located on the center board.
  • Rylee Smith
    Yes you are right the solution remains the same.
  • Rylee Smith
    I understand, it fine you can ask whatever you want regarding your TV. The kit comes with instructions and there is no need to remove any board. Check this picture:
    Also check this video on how to replace the convergence ICs. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    This is not for your TV however, just an example on how to replace them.
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi Model WS 55511 was made in March of 2003. I turn it on and it goes right back off again. On the front of this TV I only have an Enter button, a menu button. an A/V Reset Button and a Device...
Device is the same as input--try the self check, when power light goes off press and hold it and menu at same time for five seconds and release.
Device means input.
Let me know error code and I will help you more than anyone else.
SD TECH
Sep 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55857 turn on/auto turn off problem
After it shuts off, you need to get a code from the tv by pressing the menu and device buttons together for 5 sec. A code will flash at you made up of 2 digits. Example. 2 flashes a pause and 2 flashes points to a convergence failure. If this is not your code post yours and I will help you.
Jul 06, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi ws 65857 no picture but screen pulsates. bulbs ok
code 12 indicates no fault. tv probably needs the high voltage board rebuilt, have a shop do it. Maybe you need to check all the connections.
Aug 30, 2009 | Televison & Video
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
65 in Mitsubishi rear projection tv won't power on.
Go to the set and when turning it on doesn't work push and hold down the MENU and INPUT buttons at the same time until the LED starts blinking. It should be a two blink sequence like 1 blink pause 2 blinks long pause and then repeats. Repost the blink sequence and that will narrow down what the microprocessor thinks is the problem area.
Jun 09, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55857 55 in connection problem
there is a setting in the menu under setup i believe it is called
"LABEL VIDEO INPUTS". check you owners manual. you need to make sure that
the DTV input is set to YPbPr NOT RGB.
Feb 22, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
