Question about HP PSC 1610 All-In-One InkJet Printer
Won't Print. Prints but no ink is used so nothing is being put on paper. Changed ink cartridge, shut down and restarted, tried many times. Cannot print. ???
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Printer still keeps saying check ink
Did that start with new ink or with part-used cartridges?
Either way will the printer let you clean its heads and if it will, what happens if you clean them at least four times in a row without doing anything else in between, please? (that includes no test prints, no shutting down and restarting - nothing but cleaning at least four times in a row)
Otherwise are you using the maker's own ink and either way, how long ago did it last print successfully?
Aug 24, 2016 | PRINTER Office Equipment & Supplies
Everything is setup properly and the printer actually attempts to print, but nothing is showing on the paper---the ink carts are full, but I have not used printer in a year
It could be that the nozzles on your cartridges have clogged due to long period of non-usage. Try to follow the steps below to clean the print cartridge nozzles:
Using the computer:
  1. Load plain paper. For help, see Loading paper.
  2. Open the Lexmark Solution Center. On your computer, click Start menu > Programs / All Programs > Lexmark 4300 Series > select Lexmark Solution Center.
  3. From the Maintenance tab, click Clean to fix horizontal streaks.
  4. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print the document again to verify that print quality has improved. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Using the control panel:
  2. Press Menu. The menu appears.
  3. Press the down arrow button until you highlight Clean Cartridge. Press Select.
  4. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Aug 15, 2011 | Lexmark P4350 All-In-One InkJet Printer
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
Pixma MP150 Will not print. Error 2 says paper out.Won't print no matter how much paper is put in Recently replaced color cartridge. Have reset cartridge, shut printer down and restarted. Nothing works
Are you using a factory new Canon cartridge or a third party cartridge or even worse a refilled cartridge.
80% of the time, that's the failure.
Don
Feb 24, 2010 | Office Equipment & Supplies
We changed the ink and the red light and green
Some times you need to find the epson tools that comes on the CD to reset the printer. If you have upgraded the computer you may need to update your drivers at the epson sight.
Once you have opened the epson tools try cleaning the print heads.
then it should reset the inking system to default and read the new cartridges. If this doesn't work try shutting down the printer and removing the ink cartridges, restart the printer and allow it to find no cartridges the go through the process of reloading the ink cartridges again and cycle the printer.
If this doesn't work you may need to try and find a cleaning cartridge for the print heads. Since the printers always check to see if ink is getting to the print heads if there is no ink flow it will always come up like there are no ink cartridges installed.
Hope this helps
Make sure paper is in properly they can be very picky about that.
Try turning it off wait three minutes and turn back on.
Then
Push Paper refill button Wait for cycle and see if paper light stays off if so...
Push the ink button
Sep 18, 2009 | Epson Office Equipment & Supplies
Prints nothing on paper. checked ink cartridges
please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Sep 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Acts like it's printing, ink is good, but nothing prints out on paper.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
HP PSC 1610 All-In-One InkJet Printer Logo
Ben Johnson
