Question about Honda Garden
Do I mix oil in the gasoline for my Honda Harmony 215 lawn mower?
canbruce75
  • 1776 Answers
SOURCE: GOT GASOLINE IN OIL TANK.
Empty the tank of the tainted gasoline (Maybe add the right amount of oil and use it for a trimmer, etc), fill tank with fresh gas and clean the spark plug, since it is probably fouled out. You may have to clean the carb with some carb cleaner, and clean your plug a few extra times, but it should be fine. Hope this helps. Good luck.
Posted on Jul 15, 2009
  • 22 Answers
SOURCE: Oil coming out of the carburetor of my Honda Harmony 215 mower
unless the ground was a steep slope while mowing or the mower was tipped over 35 degrees or more in any direction except with the handle bars down (spark plug up is ok), it will most likley be a blown head gasket between the pushrod gallery and cylinder. remove the head and get it re-faced then assembly with new gasket. valve adjustments are 4 thou inlet and 6 thou exhaust
Posted on Jul 20, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
SOURCE: My lawnmower won't start
my lawn mower has a new battery but will not start
Posted on Nov 02, 2009
  • 15 Answers
SOURCE: My honda harmony 215 lawn mower starts but then
most gasoline today is being blended with ethanol and is the core source of most outdoor power equipment with starting and stable running after being stored for the winter. The ethanol gums up much quicker than traditional gasoline. One product that I used was from Walmart and made by the same company that makes Stabil fuel products. It is called Start. Mix with up to 1 gallon of gas(I placed directly into my Honda Harmony 5.5 mower gas tank and ran while mowing and it cleaned the carb without having to remove it. It is running as it did when new. Worth a try
Posted on Apr 02, 2010
Lawn mower where is the serial number on a honda harmony 215 SX
on the deck behind the engine. if it's not there then it's gone. if your the original owner a Honda dealership can look up the name and get that info
Feb 20, 2017 | Honda Garden
Honda harmony 215 sx blades will not engage
Tighten blade nut. Shaft maybe bad, bad motor.
May 06, 2012 | Honda Garden
Problem:gasoline mixes with engine oil on 6hp. Craftsman lawn mower.
Hard starting? excessive choking caused by excessive cranking, try a tuneup, beware of Gas in the
oil, it will thin the oil out and result in the engine throwing a rod or seizing
Jul 05, 2011 | Garden
My Lawn mower seems to be produced by ALKO, but has the Briggs and Stratton emblem also. It is the 40b model and having just inherited it, I am trying to find out if I put just petrol in or whether I need...
Hi scottcoles5...
The easy way to find out if the motor is 2 or 4 cycle is to check to see if the engine has oil in the crankcase...if it does it is a 4 cycle and you will NOT have to mix oil with your gas. 2 cycle engines do NOT have an oil in the crancase and depend on the oil you mix with your gasoline.
You can also check the color of the gasoline in the tank, most 2 cycle oils contain a colorant to color the gas to let you know there is oil in the gas...
Free Answer...Please take time to rate me
May 31, 2011 | Briggs & Stratton Briggs Stratton...
Does the recycler use gas or a gas oil mixture
Your recycler mower is either gas or electric (as you may know). The gas models use straight gasoline. You do not mix oil with the fuel.
May 02, 2011 | Toro Power Lawn Mower
My honda harmony 215 lawn mower starts but then shuts down immediately. Carb cleaner fires it up again but then dies.
Nov 04, 2009 | Garden
I have an older Harmony II HRT 215. The drive
the best thing to do is take the model number and order a belt from honda which will be the right size and thickness
Aug 09, 2009 | Garden
Jul 18, 2009 | Garden
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
256 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
