Question about Canon PIXMA MP780 All-In-One InkJet Printer
Will not print 6BK
I can't get the 6BK cartridge to print at all. I've changed the cartridge, deep cleaned a few times. Nothing there. What's next. I do have a spare print head.
  • rs6er May 29, 2008
    I had already removed the print head. The small black ink cartridge port on the head was covered with dry ink. I cleaned it with alcohol and reinstalled it. Now it works fine.
  • old marine
    old marine May 11, 2010
    What model printer?
I followed the intstructions posted here for reseating the print head.
I took it out and cleaned it and removed some excess ink and cleaned off the ink pad the ink cartridge touches and then did a deep cleaning and printed a test page and then my own doc and it worked!!!
thanks for the info on this web site!
ktb2
Posted on May 31, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Please see the Canon link below, and as Canon links return generic pages, type in "missing black print" (without quotes) or something of that nature. The results will include Reseat/remove printhead, among others. I have reproduced that content for you below, but I would also add that a number of folks have issues with black print cartridges, and it seems this is an issue that is fairly widespread, as one of the results is that your printer may need repair. If you have tried more than one cartridge with the same result, suggest consulting support if you don't think your usage justifies a new print head - especially if you are still under warranty. Page link is:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
---------------------From Canon-----------------------
Issue: How do I reseat / remove the print head?
Solution: Reseat MP750 / MP780 print head
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and taWill not print 6BK - mp780_ph_removed.gifd.
  7. Again, place the print head back Will not print 6BK - mp780_ph_inserted.gif down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click isWill not print 6BK - mp780_inktankclicked.gifk tank is in the correct slot.
IMPORTANT:
a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  1. Close the Inner Cover 2.
  2. Close the Inner Cover 1.
  3. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  4. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from columWill not print 6BK - mp780_alignment1.gif enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
Please post back if you need additional help. Otherwise, thanks for rating FixYa!
Posted on May 28, 2008
  • Cheryl Whalen May 29, 2008
    Glad to hear that it all worked out! Sorry there was such a delay in response, I just happened on your issue yesterday - again, glad that you are fixed up, and please don't hesitate to post again if you need help. Feel free to post to my "expert account", and I will get back to you ASAP. Best wishes -
    smartsolve
Printer not printing black
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again......
Nov 17, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon iP5000 not printing black
Here is the link to the user guide if you need it; http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10439 If you have performed all the operations in there with no success, then the part of the printhead that is under the 6bk has some blockages. This is best cleaned by dripping some ink flush solution (use gin if you have none) into the print head from above (just at the point where the hole on the ink cartridge would sit. Very gently swab with a q-tip from below with more fluid. After a day or so with the fluid penetrating from the top, clean the bottom again, clean out any excess fluid you can from the top (don't get any q-tip fluff in there). Then run a clean/test again. Hopefully this can solve your problem after a few cleans, but blocked Canon printheads are not always unblockable. You can purchase the complete replacement printhead, although I wasn't able to find a price - this link for service; http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=184&modelid=10439 Hope this helps :)
Apr 26, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
Canon pixma mp830 not printing yellow.
This just started happening to me also, I have been using the printer without issue for a few years. Replaced the yellow cartride, still no yellow. Anybody else seeing this?
Feb 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Our Mp760 just decided it would stop printing. It will still run as if printing but there is no ink. We changed the ink cartridges and still no luck. A few of the items on the page print if they are color...
Are you using OEM cartridges or aftermarket/reloaded cartridges. Your problem sounds like the nozzles are clogged and need to be deep cleaned. To perform this you need to put in new OEM cartridges and run the deep cleaning (at least 3x) and the alignment utility. This should clear the clogged nozzles.
Aftermarket/refilled cartridges do not always meet the manufacturer's specifications for quality. If you want to try a good source for aftermarket cartridges, try cartridges from LDproducts.com for your printer. I've never had a problem with their aftermarket cartridges.
Please rate this solution. Thanks.
Feb 04, 2010 | Canon PIXMA MP760 All-In-One InkJet...
After a month or two of disuse my i860 6BK cartridge will not print. On a nozzle alignment printout the 6bk color bar below the 6y bar is absent. The square labeled "F" in the lower part of the printout is...
Hi
You can try this I found.
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 03, 2009 | Canon i860 InkJet Photo Printer
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
Pink bars across all pictures in document. Have deep cleaned the printer several times as well as print head alignment. Even changed the magenta cartridge. What should I try next? Thanks, Carol
I had this problem too. I don't know exactly what fixed it but it's working fine now. I removed all the cartridges and then put them back in, and ran through the nozzle check & clean cycle a few times. Now it's printing beautifully.
Jul 13, 2008 | Office Equipment & Supplies
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printing light colors does not work
You RINSED the printhead???
I wouldn't do that again.
Try taking a damp cloth and dabbing it against the printhead nozzels until you get lines forming on the rage from the ink (the nozzels you're having trouble with specifically).
Erice
Oct 29, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Won't print in black
open your list of printers. r/click on the 780 and open properties. fo to the last tab "maintenance" and run cleaning 2 or 3 times then run deep cleaning 2 or 3 times. and see how this helps. If you've never done it before you might want to take out the print head and clean it with alcohol. Take out all the ink like you were changing them then reach in and gently pull out the container that holds the ink. This is the print head. Clean it and replace it, then run clean and deep clean again. run Nozzle check to see how clean it's become and you'll definetly see a difference in your printing. good luck
Sep 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
436 people viewed this question
old marine
old marine
