Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
I have a Westell A-90-750015-07 model modem, connected to my home PC... It works well for a while but then the internet connection drops and when I try to navigate to a webpage it says "server not found" the firmware is up to date, I don't know if my configuration settings are correct? what should they be if I have my ethernet cable to E2..
Shuttle83
  • 1139 Answers
SOURCE: Westell Linksys 327W
Ok right I love these issues. Here we go!! First I want you to determine if this is a no sync issue or if this is a no route issue. Know this is the difference between working with Verizon or working with Verizon On-Line. If you have a sync issue which means the DSL light is off or blinking, this would be a Verizon proper issue and is easy to have fixed, however if the DSL light is on and the internet light is off this means that you have not received a PPPoE derived address and thus while you have DSL (Digital Subcriber Line) sync you do not have connectivity to a gateway router to route you to the Internet. I want you to log into you DSL modem (http://192.168.1.1) then using your login ID and Password the one you configured for the Router not Internet access. And the go to the screen that show your DSL connectivity see if it is up or down *Remember DSL refers to the layer 1 connectivity, and PPPOE refers to the layer 2 connectivity". If the DSL light is on this meaans that you have to call verizon and say "My DSL light is on, but I am not getting an IP address which means my layer 1 connectivity is working, but my layer 2 PPPOE connectivity did not provide the platform for my layer 3 level to be built". so this now becomes a task of troubleshooting the layer 2 systems (PPPOE server, and IP Address delivery systems, and Redback SMS). Instead of a half hour of "is your modem plugged in". If your DSL light is off then your layer 1 systems are not working this could be anything from your modem to the ASAM ( ATM Subscriber Access Multiplexer ) system or DSLAM (Digital subscriber Line Access Multiplexer). In any case if the DSL light is off they just have to figure out why. This can be done at the central office by disconnceting your cable and pair and trying to sync up at the vertical shelf (Ca/Pr) or at the split bank. If they sync up the problem is outside, if they do not sync up the problem is inside the CO either at the Split bank or the DSL OE block. If the problem is in the CO they will fine and fix it. If the problem is outside, what you can do to expedite things is to take your DSL modem to the NID (Network Interface device) and connect to the phone line that has DSL on it and try to sync up there. If you can sync up the problem is inside of your house, if you can not sync up the problem is outside of your house prior to the NID and thus is verizon's responsibility. I hope this helps.
Posted on Sep 07, 2007
SOURCE: westell 327w
Your router is for DSL not cable
Posted on May 01, 2008
Dionnow
  • 61 Answers
SOURCE: remote access through a Westell Wirespeed Versalink model B90-327W15-06
Garbow,
You need to setup a feature called "Port Forwarding." Do you know what program you will use to access your desktop remotely? I recommend windows windows remote desktop or VNC programs.
The link below is a complete walkthrough on how to enable port forwarding for windows remote desktop from a westell 327.
http://www.portforward.com/english/routers/port_forwarding/Westell/D90-327W15-06/Remote_Desktop.htm
There is an alternative option called a DMZ which you could use. Let me know if you need further assistance.
Posted on May 14, 2008
  • 192 Answers
SOURCE: westell 327 modem is listed on itouch; itouch asks for password
lock on the botom of the router it might be locking for the WEP password on the label
Posted on Jan 04, 2009
SOURCE: Cannot connect to wireless on westell 327w modem
Have you tried updating the firmware on the router?
Posted on Mar 12, 2009
Will a westell modem work on a computer that had dial up.
What do you mean that pc has dial up? Did you mean that you have a dial up connection to the internet? If that is the case, using a westell modem is not necessary because dial up connection just uses a phone cable directly plug in at the back of your pc where you will see a port for phone cable. If you have a dsl connection and your pc is currently configured for fial up set-up, then you can use the westell modem but need to check first if westell modem s compatible with your internet service provider.
Sep 07, 2011 | Computers & Internet
I need help connecting a westell 7500 router/modem,i want to get a notebook on line. i didnt receive any intsructions.i need help connecting the westell 7500 to my pc and notebook thanking you.
Westell makes a line of broadband home networking products that enable residential customers and users in small businesses to access and share broadband services. These inexpensive DSL router/modems offer multi-users Internet LAN access for home or business applications. The Westell router/modems allow you to have the benefits of the "always on" high-speed broadband Internet connection without losing the ability to receive voice calls over the same phone line.
  1. Step 1 288254_thumb.jpg Connect one end of the Ethernet cable to the computer's Ethernet port. Connect the other end to the Ethernet port on the back of the Westell router.
  2. Step 2 Connect the barrel end of the router's power cord to the connector labeled "12 v" on the back of the router. Plug the other end of the power cord into a wall outlet.
  3. Step 3 Connect one end of the DSL phone cable to the DSL line jack on the back of the router. Connect the other end to the wall jack.
  4. Step 4 Wait for the Ready and the Link LEDs to glow steady green. The router is now ready to use.
Nov 15, 2009 | Westell Wirespeed VersaLink...
AT&T Westell modem keeps dropping internet and i have to unplug power cord and reconnect to regain connection at least twice an hour
If that is a westell 6100F series, that is the problem. Westell admits they had trouble with that series staying connecting. Try finding a westell 6100G. I had the exact same problem with verizon.
Nov 08, 2009 | Westell Wirespeed LiteLine 6100...
Westell Modem will not connect to internet
Shut down your firewall. Hook your modem up directly to your computer. Hit the reset button on the modem and follow the instructions on the screen. You have reactivate the modem and verizon has there own program and it should start up automatically.
Nov 05, 2009 | Westell Wirespeed LiteLine 6100...
I have charter internet with a modem and i have a westell 327w wireless router/modem. How can i connect the two modems to work wirelessly?
I think the Westell Router/modem that you have must be the modem for the DSL connection.
Charter is a cable internet service provider.
You can not use 2 modems connected to each other.
You have a charter modem , you can purchase a wireless router only.
That will work.
Click Here for more info about routers
Oct 27, 2009 | Westell Wirespeed VersaLink...
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Connecting another computer
HI,
Im not sure what model of westell you are using but if you say that it has a USB port then it must be a westell 6100. With this type of modem { 3 ports } w/c are USB port , ethernet port and a phone port. Connecting another computer is technically a no-no for that device. It will create a conflict and the other computer wont work at all vice-versa. Youd experience slow connection too.
I would recommend you to just use 1 PC for this device OR you would consider on purchasing a router for that.A router is a separate device where-in you can connect multiple computers. modem --> router ----> computers { wired and wireless}. Routers are more secured and is very efficient when it comes to home networks.
Hope that helps and if you may have additional questions pls feel free to post it in FIxya.
Good Luck .
Jun 10, 2008 | Westell Wirespeed LiteLine 6110 Modem
More than 1 computer accessing internet.
call linksys 800-326-7114 to assign an individual ip address for each pc...that should be a conflict on ip's of pc...
Jan 06, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
494 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
