No sound from speakers
I moved my computer and when I reconnected the system, my speakers wouls no longer work. The light goes on and the system says that eveything is ok, but there is no sound. I contacted Acer and they had no suggestions that worked. I even bought a new set of speakers, but still no sound. HELP!
  • parlez May 15, 2008
    My computer is an Acer aspire t180
  • Kimo1 May 17, 2008
    I have an Acer noteook, Aspire 3680. I am trying to use headphones for the first time and do not get any sound, the speakers work fine. Is this a software set up change or something else?
    I have tied other headphones and external speakers.
    Jim
    Sergeant:
  • 291 Answers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
Posted on May 18, 2008
Lost my sound when I moved my computer
Have you checked speakers on another computer. Get it checked first if it working on another computer or other device. If it working reinstall realteK audio drivers.
Nov 04, 2017 | eMachines ET1810-01 PC Desktop
Everything is plugged in and this morning the simply woul;dnt work i cant get any sound from the speakers either, do you have any tips
Has something changed your default playback device?
USB devices can sometimes do this.
Right click on the speaker icon in system tray, or go to sound properties in control panel
Sep 16, 2010 | Logitech Z-2300 Computer Speakers
Sound goes out & speakers "disappear" from computer prefs panel
I would open it up (assuming it's a desktop pc not a laptop), and make sure the sound card (if it's an expansion card and not built-in to the motherboard), is properly seated (all the way in) in the expansion slot.
Feb 18, 2010 | Harman Kardon Harmon Kardon SoundStick II...
I moved and of course disconnected my computer. As I try to reconnect color to color, i get no green light and no sound. How do I reconnect?
reconnecting speakers only requiring into the single port in back of the cpu and plugging in the ac cord. Powering the speakers on. If no sound make sure port is plugged in in back of cpu, restart. Power on speakers should have sound. If not write back to clarify.
Dec 08, 2009 | Gateway Edison Computer Speakers
Sound only works with headset. No longer comes
If the sound is working through another device then it seems that the internal speakers are bad. Because if the sound card was bad you wouldn't have any sound whatsoever, same goes for drivers. Probably just some bad speakers. If you have some other external speakers try plugging them into the headphone port and see if that helps.
Mar 08, 2009 | HP Pavilion dv6000z Notebook
Help no idea on connection hook up
The mini stereo plug goes into the green jack (three jacks in a row) on back of computer.
Dec 30, 2008 | Logitech X-240 Computer Speakers
I moved, and now my speakers won't work
check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
Aug 16, 2008 | AOpen MS-810 Computer Speakers
Z-680 optical acting very strange
I bought a new cable. The old one was bad.
Mar 18, 2008 | Logitech Z-680 Computer Speakers
Computer stopped recognizing speakers
This is due to your Drivers for your sound device are unavailable plz make sure that you have installed all your audio devices driver! try to reinstall it! it will help you
Dec 07, 2007 | Polk Audio AMR50 Computer Speakers
249 people viewed this question
 Grubhead
Grubhead
