Question about Fisher and Paykel Washing Machines
What does error code 130 mean - Fisher and Paykel Washing Machines
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Error code 130 means you have an error known as SINGLE ROTOR POSITION SENSOR ERROR.This means either the rotor sensor,which is attached to your motor, is faulty or the wiring to the rotor sensor is faulty or your control module is faulty.To test the rotor sensor you need a device called an RPS tester.I can help you check the wiring to the rotor sensor but unfortunately I can not help you test the rotor sensor without you having an RPS tester.Also to help you test the wiring can you borrow or have you got an electrical test meter .Please reply on how you would like to proceed and I will help you as much as I can. Looking forward to your reply.
Posted on Sep 14, 2010
Error code 130
IF a Fisher and Paykel, see this link:
http://ths.gardenweb.com/discussions/2427379/fisher-and-paykel-gwl11-error-code-130
You need to list brand (if not also model number) when you post white goods questions. Codes are specific to a manufacturer.
Mar 04, 2015 | Washing Machines
What does Cold 130 mean?
Error code 130
130.
(10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: 1. Check for corrosion on the edge connector of
the Rotor Position Sensor and the Motor
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S.
tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Sep 02, 2012 | Fisher and Paykel GWL11 Top Load Washer
Error code 130
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Aug 11, 2012 | Fisher and Paykel IWL12 Top Load Washer
What is a code 240 and a code 130
240. (11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
faulty.
Jun 03, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel 1w812 keeps coming up with a 130 fault code , any ideas
The 130 code means you have a Single Rotor Position Sensor Error.
Nov 20, 2010 | Washing Machines
My washing machine keeps coming up with error 130 and wont go past this. can you let me know what this means.
Hi just read your posting.Now error code 130 is called SINGLE ROTOR POSITION SENSOR ERROR.This means the rotor sensor which is attached to the motor is faulty or the wiring to it is faulty or the control module is faulty.Unfortunately to test the rotor sensor you need an RPS TESTER.I can help you test the wiring to the rotor sensor but unless you have an RPS tester I can not help you test the rotor sensor.Please reply and let me know how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washer will not spin there is water on the floor and has a fault code of 130 it is fisher+paykel brand model numberWL26CW1
Hi just read your posting.Error Code 130 means your fault is called Single Rotor Position Sensor Error.This component is attached to your motor which is underneath your machine.What concerns me is your machine is leaking.Did the Error Code appear the same time your machine started leaking?The reason I am asking this is because the water could have damaged the rotor sensor.Is the water leaking underneath the machine?Please reply with additional information and I can help you rectify this fault.
Jul 20, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Fault 130 Cold water valve cycling on and off rapidly. On spin, pump cycles on and off rapidly.
Hi just read your posting Now error code 130 means you have a Single Rotor Position Sensor Error.That means the Rotor Sensor which is attached to your motor is faulty or the wires to it are broken.The other fault it could be is the motor controller.The only way to test the Rotor Sensor is with an RPS tester.I can help you test the continuity of the wires that go to the Rotor Sensor if you have or can borrow an electrical test meter.If i had to guess which part is faulty, It would be the Rotor sensor.Hope this helps and please reply for further help.
Jun 06, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
268 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
