Question about Samsung RS2630SH Side by Side Refrigerator
Ice Maker not flipping
My ice maker water dispenser is working but it will not flip the ice into the tray. It adds water as though the tray flipped causing water to go everwhere.
  • Anonymous May 15, 2008
    EXACT SAME PROBLEM
  • 828 Answers
May very well be a stripped gear in the drive unit. Unplug ice maker and remove mounting screws. Out of the freezer remove front cover and inspect drive gears for damage. Replacement gears should be available through a dealer for you make and model number.
Posted on May 15, 2008
Icemaker will not flip the new ice out from the tray. 25" whirlpool side by side-water and ice on front door A new ice maker does the same thing
This sounds like a temperature problem. Check freezer for 0 to 10 degrees.
Most im's will not flip until temp reaches at least 10 or 15 degrees for most fridges.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 19, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi, my fridge stopped producing ice some time ago however I though it was because we had to replace the filter. We did this and is still not making ice. I have tried to get the ice maker to flip out...
if the ice maker has ice in but will not release / then i would ck the heater that warms the tray . this causes the ice to release then the fingers will remove the during the harves cycle .. when the mold heater is bad it''s best to replace the icemker / mm
Oct 31, 2010 | Refrigerators
The icemaker of our Samsung side by side refigerator gets full and clogged up frequently and although we can hear the machine churning inside, ice is not dispensed. We have put in a new water filter after...
Either the icemaker support is broken, DA61-01801A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, part number DA63-02284B
Good luck,
Vlad
First Choice Appliance
Aug 17, 2010 | Samsung RS2630SH Side by Side Refrigerator
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Ice maker
If there is not other problem it will start to work after there is water in the ice mold and it freezes. It will then dump and refill with water.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 02, 2009 | Refrigerators
Amana Fridge isn't filling the ice tray with water...=/
it seems to me (no expert) that you have an ice buildup in the tubing to the freezing portion of that unit. I can only suggest to turn off the Refrigerator for a little while, an hour or two at most, and see if the tubing thaws.
Aug 30, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Not producing ice
Did you by some chance put the ice maker in "vacation" mode. There's a little lever on it that turns it on and off. Check your owners manual - you do still have the manual don't you!
Aug 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice maker doesn't work!
Could be the sensor for the ice maker to fill up....we have a wire bar that flips up when full so it shuts off ....also a piece of ice gets stuck in the plastic fingers somtimes but since you defrosted it that shouldn't be the problem....not sure if you can take the ice maker out yourself ...better call the repair man ...
Jan 12, 2009 | Whirlpool Refrigerators
Ice maker not dispensing ice
Hi!!1 in order for the ice harvest the freezer must be atleast 10 degrees make sure..I wish that i knew which brand of frig you have.you are going to have to manually jump start the ice maker and see what happens..Good luck..Let me know model number and serial..
Jan 04, 2009 | Whirlpool ET1FTKXK Top Freezer...
Ice tray wont flip
check the very back of the ice maker and see if the piece that holds the rear portion of the ice maker has broken into little pieces causing the tray not to flip. the piece costs around 12 dollars and should be available for the unit that you are talking about. Thanks for using FIxYa and please don't forget to rate the solutions when thru please. Tahks again and have a great 2009!
Dec 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
275 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
