Question about Sony KP-65WV600 65" Rear Projection HDTV-Ready Television
Looks like a double picture with red/blue/green line. I here there is a conversion chip you can buy. I already tried the convergence guide in the mauel. How do I fix ?
    Top Expert:
  • Sony Master
  • 14,553 Answers
The set will need to have both of the STK-392-560 convergence chips.
I have photos of what the board looks like and the chips.
A pair can be purchased on EBAY for under 14 dollars.
This can be a do it yourself repair and I am able to tell you what is needed and how to do it.
Let me know if I can help with a very helpful rating on this solution and I will assist you.
SD TECH
Posted on Sep 13, 2010
Red and green do not overlap, it becomes a double image.
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 11, 2010 | Philips 43PP9202 43" Rear Projection...
Green Out Of Focus
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 30, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Double picture and colors are neon green and pink
Your TV most likely has fone of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 20, 2009 | Zenith R57W46 57" Rear Projection...
Getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Double image, blue adjusted, red won't adjust
Your TV most likely has one or more possible problems.
  • Screen looks 3D
Apr 19, 2009 | Philips 51PP9910 51" Rear Projection HDTV
My picture has double image and red shadow top and bottom
  • Screen looks 3D
Apr 03, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Double Image Red and Green
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
43 philips problem with green
  • Screen looks 3D
Jan 24, 2009 | Philips 43PP9202 43" Rear Projection...
Curved red lies at top/bottom with some double vision in lines
This is from another fixya article but its relevant to your problem.
  • Screen looks 3D
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Apr 25, 2008 | Samsung HCM5525W 55" Rear Projection...
The color keeps going out
The repair tech used cheap parts or did not replace both convergence chips.
  • Screen looks 3D
Nov 12, 2007 | Sony KP-53V80 53" Rear Projection...
Sony KP-65WV600 65" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
