Question about Kenmore Washing Machines
Cold water wont go into machine. I have replaced the intake vaulve and still wont work. Hot water will
  • 1,305 Answers
Check the screen washer on the cold water hose. Many times these get plugged up and keep the water from flowing into the machine.. turn the valve off at the wall, and then take the hose loose from the valve.. check for cleanliness and flow. You can buy replacements at the local hardware stores..
Posted on Sep 13, 2010
Soloniod faulty
check the filters
at the intake the solinoids {water intake valves}
there is a small filter
you need to turn of the hot and cold water
like under the sink
take off both hozes hot and cold
then take out the filters at the machine intakes
and clean them
you can take out the filters
using flat nose plyers to gently pull them out
clean them out from brown crypto spyridion carcus
and other rubbish
you can leave the filters out and run thru the whole machine on like 30deg with a calgon tab
does help {not scotland no lime here }
then place the filters in the intakes again
or replace the valve if it leaks water after cleaning
then the spring in the valve of the valves solinoid coils isnt so good
and needs replaced
but can just be a blockage
above all if its a new machine you just got
perhaps it been in a low presure area so the valves will be
low presure hot and cold
usually its just the hot that is low presure
so you need to check the cold water is getting plenty on like 2 -3 bar presure...
Mar 05, 2015 | Washing Machines
No water is getting into the washing machine. Error code display and soap is still in dispenser.
machines have a hot water and a cold water intake
if the water cold isnt getting to the blue intake it wont work
as you have an error code
post the error code it displays
you posted insufficient info to come to a good recon
Sep 24, 2014 | LG WM0642HW 4.0 cu. ft. Front Load Washer
Water intake in machine is not working.
try using the hot water pipe on the cold water switch the washer to hot if the water comes through you need to replace the cold water inlet valve
best of luck
please rank this advice
Dec 28, 2010 | Washing Machines
Water goes into the washer (model GHW9150PW0)
your inlet vaulve is sticking and allowing water to trickle through, only solution is to find if it is your hot or cold vaulve and replace it
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
New whirlpool wtw5100VQ, will not fill hot/warm water,
Remove lid and just check connectors on rear of inlet vaulves are not earthing. Hope this helps. Also to check it is not a faulty solonoid remove wires from 1 terminal and tape them up, then put machine onto hot fill, if this does not blow trip switch then solinoid most likely at fault. Please ensure you disconnect power before touching wires. Good luck hope this helps
Feb 12, 2010 | Washing Machines
Water continually goes into the washer. Washer
your inlet vaulve is no good, you need to change complete fitting, dut first need to find out if it is the hot or cold vaulve. assuming it is hot and cold fill.The electric solonoid can be reused, as long as the rest of the vaulve is replaced
Feb 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Matag alantis no cold water
check to see if you have power to the fill valve when the cold water should be going in;(reverse the connectors on the fill valve) i.e. hot now will not go in... replace the fill valve: (buy it at an appliance parts store) (inexpensive) it's an easy replacement job
Jun 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
The cold water seems blocked and wont fill up the machine. What do I need to do?
if no cold water then check the water inlet valve for possible obstruction at screen in the valve or the fill hose it may have a screen in it
if not the problem the verify that you have voltage to the water valve if you do replace the water inlet valve
Apr 21, 2008 | Washing Machines
Washing Machines Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
