Question about Moen Home
How difficult is to change a bathroom/vanity top sink faucet -MOEN two handle? Do I need to call a plumber? What tools do I need? Thank you.
  • 43,501 Answers
If you have a good socket set that has a fairly long extension it is not that hard....the worst part is trying to work in behind the vanity bowl....
That being said, you never know... if water has run down through and corroded everything it can be a real nightmare...
my advice would be to take a gander up there behind the bowl and see what you have and what condition thingss are in before starting anything...
heatman101
Posted on Sep 13, 2010
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
Moen 2 handle bathroom sink faucet, ca84004 series. cold faucet functions fine. hot faucet does not shut off. handle turns as cold does but hot does nothing. water must be shut off from wall supply...
Try going to their web site and selecting consumer support. Usually the bathroom sink faucets, you can unscrew the handle with a Phillips screw-driver and then twist the body of the faucet off. Then there will be a nut to screw off, to remove the inner "guts". It sounds like the rubber seal is worn out on the inner faucet assembly. If so, then all you would have to do, is to replace the rubber seal. I hope that this helps you out. If not, then I would contact the company and see about a replacement faucet, depending on your warranty! If worse comes to worse, then I would call in a professional plumber, to assist in fixing it! Good luck my friend.
Jul 06, 2011 | Moen Plumbing
When I turn on the cold or hot water sink faucet water leaks out from the top of the cold water faucet . I took the outer casking off and can not figure how to remove the stem. I removed the ring but...
if you have the ring removed, screw the handle back on and pull up on it,, your leak is probably due to a worn , torn , "O" ring,, and Moen parts are found at most hardware stores ,, ( including Home depot , and Lowes) On Moen faucets , Look for the dent in the flange that squares off,, where that square is on the ring, is where the retainer ring is that holds the faucet in place ..its a "C" clip with a head on it, remove this ring and the assembly should come out , be sure and use plumbers grease when replacing the O rings,, they last much longer that way
May 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
My moen bathroom sink handle came off. The srew into the handle comes up from the stem? how do I access the srew to reinstall handle? Thank-You
pop the cap off top of handle with steak knife, screw is underneath,unless yours is like the one pictured,then its an allan screw from the back.you had one when it was installed and,these can be really stuck
Jan 28, 2011 | Moen Bathroom Sink Faucet - 4-inch...
I was able to figure out how to get the handles apart, but can't figure out for the life of me how to get the center spout removed. Faucet is a Moen & Villeta Two Handle Lavatory Faucet
I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
Sep 15, 2010 | Moen & Villeta Two Handle Lavatory Faucet
Trying to put new cartridge in my moen bathroom faucet and i don't know how to do it. It is a teardrop one handle faucet. Please help a single woman not have to call a plumber!!!
shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
Apr 25, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Ihave a two handle Moen bathroom faucet that the right handle came off showing a broken plastic part inside, how do I get the broken part out?
There is a little cap on the top of the handle, after removing in there is a philips screw under that and that will release the broken plastic part.
Mar 18, 2010 | Moen Kingsley Two Handle Bathroom Sink...
Plumbing
Hi rbyerly,
I'm Harvey the Master Plumber.
Your problem is:
remodeled bathroom,installed new moen valve and hardware. Now water is coming from both the shower head and the faucet when the diverter is in the down postion. Question; Is this a single handle or three handle diverter? Assuming it's a three handle, it should just be a mater of adjusting the center handle. If single, the diverter is in the spout not the valve. I don't know how to direct you further without specifics. Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 06, 2008 | Home
Home Logo
144 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
