Question about Nintendo Video Game Consoles & Games
Error code 52020 nintendo wii - Nintendo Video Game Consoles & Games
  • Peter Wharton Sep 14, 2010
    Are you connecting directly to the modem or to a router?
  • 47 Answers
SOURCE: error code 32032 (wii)
you need to set up connection for wireless if its a wireless router then set it as connection 2 then search for your router then input the wep-psk or wpa psk code thats on the back of the router
Posted on Jan 27, 2010
  • 78 Answers
SOURCE: wii connectivity errors
this means that the router is not compatible with wii there is no magical fi for this pandemical problem unfortuantly
Posted on Apr 08, 2010
  • 1234 Answers
SOURCE: how do i get connection 24 on my wii?
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
_____________________________
Error Code: 51421 The Wii console is not able to connect to your wired router or modem.
Posted on Aug 26, 2010
  • 1234 Answers
SOURCE: i purchased a nintendo wii point to get internet
Hello Sir
Error Code: 50300 The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
Posted on Aug 29, 2010
  • 142 Answers
SOURCE: error 52020 code wii
Posted on Oct 02, 2010
Error code 11182
Nintendo Wii Console
Katie that may be a Wii support code.
Wii Support Code: 11182 - Successful connection test
If you receive a this code, your Wii was able to successfully connect to your wireless network.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wii Error Code Lookup
Nintendo Customer Service Nintendo Wi Fi Connection Support Code Results
Mar 30, 2016 | Nintendo Wii Console
Have connected wii to cable via cisco asa 5505 box. getting error code 52020. have restarted comcast modem to no effect.
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
Aug 09, 2011 | Nintendo Wii Console
I'm trying to connect my Wii to the Internet. I currently do not have a wifi connection but I have the adapter that connects to the internet. I have already changed the connection on the Internet...
you can try this step on how to connect your wii console on internet...
if this help you please rate me thank you sir.....
Jul 05, 2011 | Nintendo Wii Console
Error code 52020
Check out the Nintendo guideline
Tell me if you fixed it.
May 22, 2011 | Nintendo Wii Console
Im trying to connect my wii to the internet .I have the lan adapter connected to my modem. I am not getting a connection and error code 52020 is on my screen. what am i doing wrong?
You probably have a firewall on your PC (or mac), or router preventing you from connecting to the internet, either plug the cable to the router, disable the firewall (if using a Netgear router, disable the "SPI firewall" under the "WAN setup" of your router), your Internet Service Provider or ISP might be preventing systems like the wii to connect, check with the ISP to see if they are or not.
May 07, 2011 | Nintendo Video Game Consoles & Games
Bought a pre owned wii and im trying to hook it to the internet but it says error 52020
4. If the connection test fails, try a Manual Setup with the Wii console, using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
Mar 15, 2011 | Nintendo Wii Console
Keeps showing error code 52020
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=lang
Jan 28, 2011 | Nintendo Wii Console
WHAT IS ERROR 52020?
It is an error of falior
Oct 31, 2010 | Nintendo Wii Console
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
Sep 13, 2010 | Nintendo Wii Console
The wii is unable to connect to internet
It seems that it can't establish communication to your access point.
Nintendo Forum explanation:
Wii Error Code Group: 52020, 52021, 52022
Summary: Connection difficulty with either router or modem.
If automatic configuration is not working (it expects DHCP to anser; i.e. to get an assigned IP address) try manual configuration. Enter the values as you would on your PC to connect to the network.
Consult the Nintendo Forums for detailed help.
Jun 12, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
136 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
