Question about Magnavox Televison & Video
I have a magnavox projection screen, i dont now the model number or anything like that but the sounds good, the picture is there but it shows green and red were it shouldn't. what should i do?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue is caused by bad convergence ICs and you’ll need to open the back of the unit and replace the parts that have gone bad to resolve this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 14, 2010
Picture shows blurry
You will have to determine which of the picture tubes has contaminated fluid. To do this, you have to pull the screen off and see which tube is blurry. You will find a red, green and blue tubes when the set is on. To learn how to remove and replace the fluid, please check the following web site. www.TVRepairKits.com. Be sure you have the model number and know the symptoms you describe to repair this. Thanks for asking and show all hands of support!
Mar 29, 2011 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 9p6034c 60 in. rear projection t.v.
are you sure!? or maybe you set at the pip viewer! go to settings!
Oct 01, 2007 | Philips Magnavox 9P6034C 60" Rear...
My screen is discolored and blurry. Please advise..
Sounds like contaminated fluid. Each of the 3 crt's in your set have coolant to keep them cool. This coolant over time gets contaminated and causes extreme blurry picture. ITs extremely common on the Magnavoxs. Its also a pretty big job. Replacing the fluid isnt too difficult but because the tubes have to be removed it means both physical alignment and electronic alignment will be necessary. Also dont remove the green tube until you have done both the blue and red and aligned them to the green. Then do the green.. I hated doing that job lol.. I dont recommend you trying it and probably wouldnt be cost effective to pay a shop to do it either.. I recommend buying a new set... Sorry
Oct 19, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture is too red
sounds like you may have a bulb out, you can pull the screen off to access it but you have to very careful with the screens or you will damage them, only clean with isopropyl alcohol and of good quality, there will be three bulbs in there, red blue green, their location and direction is very important, so dont move them, if they all work clean then put the screens back on, and see if you can adjust the direction from the menu
Jul 03, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P5040 C104. Green power light- no sound/ no picture, fuse good.
Hey my tv is doing the same thing. The green power light with no sound and no picture and the fuse is good. I was wondering if you fixed the problem and if you could tell me how to fix mine.
Nov 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
The screen is starting to have red and green blurring
sounds like the coolant if it appears as halos. If it appears like a 3D picture its the convergence ICs.
Jan 30, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Showing double picture with a green glow
Good Day, pklove;
Green glow and double picture? Sounds like you may own a Phillips/Magnavox. If you do the TV has an convergence problem and a picture tube fluid problem.
I would say that you should call an Authorized Service Center to come to your home and give an estimate before any service is rendered.
Good Luck, big IRISH.
Aug 16, 2008 | Televison & Video
Philips Magnavox 9P6034C 60 in. Rear... Problem
I had a similiar problem. My screen would shrink in then expand. After a few months of doing this it just broke altogether. No sound or video.  Its not fixed.
You can get a repair kit from this site.
http:///www.magnavoxhelp.com
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Problems with my Phillips Rear Projection TV!!
have the coolant (glycol) in the CRT's....not as expensive as buying a new set...and sounds like it should be good as new if thats the only problem you have with it.
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
