Question about Garden
Tractor afer mowing 5minutes loses power emits large cloud blue smoke runs poorly thhen regains power repeats above description . fuel is fresh noehanol is less likely to occur when mower deck is disengaged
  • 2,973 Answers
The piston rings seem to be wearing out. Check if the oil level is receding. The blue smoke is an indicator of excess oil being burnt. When the mower deck is disengaged there is less load on the engine and hence less or no smoke. You need to get the rings changed at the least.
Posted on Sep 13, 2010
It sputters and belches out large clouds of blue smoke
mine recommends using only detergent oil rated API service classification SG-SL. Sounds like an older model and the synthetic may be to thin. Try changing the oil to a SAE 30 to see.
Apr 24, 2016 | Garden
21 hp B@S engine exhausting blue smoke
sounds like blown head gasket.
does it have a fuel pump, if so is there oil around it (by the brass colored screen)
if so then you have blown head gasket
Oct 24, 2015 | Craftsman 46 In. 21hp Briggs & Stratton...
15hp Briggs Vanguard 1cylinder runs like it's on choke emitting black smoke. What can be wrong ?
The "black" smoke has me wondering... I would suspect that you may have a broken ring on the piston, or even ha hole in the piston.
Several weeks ago I found two of my neighbors mowing lawn and pumping out heavy clouds of smoke. I went to each of them and they told me they just filled the oil. They filled it up until it came out of the dipstick hole. This results in too much oil in the crank case and not enough air, so the engine forces the oil past the rings and then you are burning oil with the gas producing a large amount of smoke. I took my turkey baster and a can to each and removed the oil until it was at the proper level. Then I showed them the dip stick and explained that the oil level must be between the two marks on the dip stick. This situation of too much oil produced a huge amount of smoke, but the smoke was more white than black.
- Joe
May 11, 2014 | Tools & Hardware - Others
MY 24HP CRAFTSMAN TRACTOR IS LOSING POWER AND OVERHEATING
gas oil and filters ...remove gas replace w fresh regular 87 octane then change spark plug simply walking in any auto store with plug in hend will be best if you dont know which to buy then check oil make sure to wipe dip stick and check oil after that finnaly replace the air filter your not far from burnning you engine you are most likely to be out of oil the fresh gas and oil are the most important but filter and plug will help things run smother check your oil and filters regularly if you use every day once a week oil check once a week or bi-weekly once a month and befor use after storage
Apr 02, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
Occasional heavy smoke on tickover, but not using oil and oil clean.
HI do you now the color of the smoke
if engine emits white smoke its not burning the fuel
it could be water mixing with fuel = head gasket even tho you
dot have water in the oil
if engine emits black smoke - that's excessive fuel to air ration
check air filter & air inlet to see if clogged
if engine emits blue smoke - excessive oil consumption
cloud be valve seals
Jun 28, 2011 | 1996 Volvo 850
Mowing keeps stalling and emitting clouds of white smoke
You probably either have too much oil in the engine or there is water in the fuel system.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Smoke from engine of lawnmower
usually large clouds of smoke are from having too much oil in the crankcase, or tipping the mower so that oil runs into the cylinder. Check the level of oil, and make sure it's not overfilled.
Mar 26, 2010 | Pool & Spa
My lawn tractor is losing power. its smoking black smoke and the smoke burns your eyes. its did it off n on the last few cuttings. today i had to stop mowing. it almost completely quite running.
First thing to do is change the oil. This should help but does sound like the mower is burning oil do to worn oil piston rings
Jul 10, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
