Question about Lexmark E323 Laser Printer
Often the feed grabs more than one page - Lexmark E323 Laser Printer
9 times out of ten its a dirty pickup roller that needs to be cleaned. When you open a new pack of paper flip through it or air it. Make sure that the humidity where you store your paper isnt too high ie away from sources of water, leaking, condensation etc.
Posted on Sep 13, 2010
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
DP80F FAX WILL NOT FEED ONE PAGE AT A TIME. IT WILL TAKE 1 PAGE , 5 PAGES , 2 PAGES . HOW DO I FIX THIS MACHINE TO FEED ONE PAGE AT A TIME
Potential solution: When putting in several sheets of paper, grab the sheets by one end, and fan the papers (spread them) at the other end. Reverse your grip and do the same thing to the other end.
Reason: paper is cut by a shear. If the blade of the shear is not perfectly sharp, it crushes fibers into the edges of the adjoining sheets. This causes the sheets to misfeed in the random way you describe. Ruffling the paper before putting it into the printer separates the pages so they will feed properly.
Nov 07, 2011 | Toshiba DP80F Printer
Front loading page grab problems.
See that top on which to place paper faxing is a green button should be positioned (to the right or left) in position with several sheets drawn as an indicator. I guess yours is positioned on a single paper which means it does not separate anything you ask.
Good luck to configuration
Oct 30, 2009 | HP LaserJet 3200se Printer
Form feeding
try puting a piece of cardbord under the paper but tape it 3mm from the roller.
Jul 31, 2009 | AMT Datasouth ACCEL-6350 Matrix Printer
Brother copier paper feed grabs 2-5 sheets at a
check the feeed rollers ateh seperation roller the one that seperates the pages is worn.. it has proberly worn the tread and if its sn=mooth or worn it wont stop multi feed
Jul 29, 2009 | Office Equipment & Supplies
Paper is not feeding into the top.
I also was not able to copy, scan or fax multiple pages through the ADF of our HP Officejet 7210 AIO, but it would print well from the computer.
It would either grab several pages at once, or not grab paper at all. The device was trying to work but had poor traction action. Not sure if that's the same issue you are facing, but if it is, this is what fixed my 7210: I purchased part number C7309-60091 which is the feed roller assembly, and part number C7309-60076 which is the separation pad from Encompass Parts, and replaced them. The ADF works great now. The HP Officejet 7210 had only 5,000 pages printed on it, so I chalked it up to our very dry atmosphere here.
Jul 10, 2009 | HP Officejet 7210 All-In-One InkJet...
Paper feed grabs more than one sheet
Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
Apr 21, 2009 | HP Hewlett Packard Officejet Pro L7680...
Scanner will not multi feed takes several sheets
compatible DVD decoder is not installed on my computer. how could i install it ???
Feb 15, 2009 | HP LaserJet 1100a Printer
Canon DR-2080c - Replacing rollers
Check for a switch on the scanner that is made to feed single pages or multiple pages. If it is on single page it can multi jam all the time.
As far as the rollers go there is a pick up roller, separation roller, and a feed roller. You can clean them with rubbing alcohol to see if its indeed the tires that are bad. The exchange kit has all three tires in it that are user replaceable.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Lexmark E323 Laser Printer Logo
134 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
