Question about Toro Lawn Mower With Toro Power Tools
How do i keep the belt from slipping off - Toro Lawn Mower With Toro Power Tools
    Problem Solver:
  • 9 Answers
What kind of mower? generally there should be a spring loading idler pulley to give it tension and/or the pulleys or out of alignment or worn out what i would do first to look at if the belt has the proper tension should only able to move 1/4 inch up or down
Posted on Sep 15, 2010
Belt keeps slipping off motor shaft
The belt may be stretched or worn unevenly.
Jun 18, 2016 | Eureka Smart 4870DT Bagged Upright Vacuum
Why is the new belt on my dirt devil featherlite repeatedly slipping off? Everything else on it works fine and the b elt is the correct size.
Hello! There is no other part that goes on the motor shaft after the belt is put on. The tension of the belt keeps the belt from slipping off. If you have a brand new belt that keeps slipping off you may not have the correct belt for the vacuum. Be sure you replace with a genuine Dirt Devil belt and the specified belt style for your particular unit. Hope this helps! If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Apr 28, 2014 | Dirt Devil Vacuums
Serpentine belt keeps popping/slipping off
The power steering pump pulley must be flushed with the power steering pump shaft,Or else you will have noise or slips right off.12_11_2012_4_28_42_am.gif
Dec 11, 2012 | 1997 Ford Windstar
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
How do I tighten the belts on my 1991 toyota landcruiser to keep from making any slipping noise? Belt only slips when I'm turning sharp in either direction.
this sounds like the powersteering unit busy saying cheers. check your powersteering fluid is topped up. keeping it topped up would keep this from slipping. the belt is tighten to the right degree. I'm sure it's just the fluid. otherwise an early sign that the powersteering system is packing up. good luck
May 07, 2010 | 1991 Toyota Land Cruiser
Cherolet 2000 malibu belt keep slipping off
SOUND LIKE A BAD BELT TENSIONER OR YOU HAVE WRONG SIZE BELT.
Oct 25, 2009 | 2000 Chevrolet Malibu
Hoover U6439: Belt keeps slipping off
The belt is stretched and you simply just need to replace it. You can get the belts you need for this model here:
http://www.vacbelts.com/hoover-self-propelled-windtunnel-belt.htm
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Serpintine belt keeps slipping off of middle wheel
If the belt keeps slipping off the you need to replace the tensioner(its the pulley you have to move to get the belt on and off,and that part should be inexpensive to replace from any parts store.
Mar 29, 2009 | 1991 Oldsmobile Cutlass Ciera
1996 buick regal custom's belt keeps shredding
The first thing i would do is try playing with the belt tensioner. it sounds like the belt is lose and when the engine warms up the belt starts to expand and slips off.
Aug 14, 2008 | 1996 Buick Regal Olympic Gold
Toro Lawn Mower With Toro Power Tools Logo
77 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
