Question about Nikon COOLPIX L3 Digital Camera
When i turn on my nikon camera the lens goes in and out a million times and makes a clicking noise and then says lens error.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 31, 2012
SOURCE: Lens is stuck open and making a clicking noise!
It costs more to fix than replace. It's quite asinine. And I wouldn't recommend Nikon again.
Posted on Jan 07, 2007
SOURCE: Nikon S200 Lens stuck inside
I had the same issue with my S210, so after reading other people's advice to send it in to Nikon and since that was going to probably cost me as much as the camera itself I figured it wouldn't hurt to try a little something. The lens on mine was a hair off center or had been pushed in on one side (barely - looking at yours you may be able to tell which side) - mine was in my purse also. So, I took my handy dandy skinny prying instrument (normal kitchen butter knife) took the battery out to make it try to open again, then when I popped the battery in as the lens tried to push out I pried the side I thought was a little lower back towards center...I heard a little pop and it worked! The lens came all of the way out and it's all good.
So, use gentle hands and try if you want, but don't think I warranty this!
Posted on Mar 07, 2009
  • 1040 Answers
SOURCE: Blurry images (after a lens error)
There is a mechanical displacement in your camera. Definitely, it is not a software problem. Actually Digi Cams are very delicate, especially small ones.... So get it serviced from a authorised service station. They will fix the problem....
Pleas rate the answer iof you find it useful.
Posted on Apr 27, 2010
Testimonial: "Thankyou for that :)"
  • 94 Answers
SOURCE: my nikon s220 shows lens error and the lens remain
Clicking noises suggest the lens is either knock damaged or jamming because of sand - probably a marginal repair.
Posted on Jun 09, 2010
Jimsta01
  • 405 Answers
SOURCE: my digital camera has a lens error
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Posted on Jul 24, 2010
My nikon S220 has a lens error makes weird noise and the lens goes in and out 6 times when i turn it on. Help
Lens is probably just stuck, because of debris or misaligned gears. The lens can in about 50% of times be repaired without having to replace it. Try to return to manufacturer. If you're out of warranty, there are third party place that fix them such as camera lens repair. There are also free camera repair guide websites that show you how to replace the lens, the part is usually available on ebay.
Jul 02, 2010 | Nikon Coolpix 2200 Digital Camera
Nikon s220 lens error
The s220 seems to be very susceptible to lens errors, usually associated with the lens barrel being unaligned. It only takes the slightest bump/drop in many cases. Fixing it is a hit or miss solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Has a good list of possible fixes.
Jul 06, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Clicking noise when it turns on and won't focus, lens error also
What you are describing is probably the beginning of a possible lens error. If the camera still operates correctly (the lens extends correctly, you can still take photos that are correctly focused) then there may be sand or dirt in the lens mechanism that will eventually cause a failure. Just as an initial step, get a can of compressed air and blow out the space between the lens barrel and the camera body. If the clicking noises continue and the lens movement is not smooth, it is time to contact Nikon support at the link below
http://www.nikonusa.com/Find-Your-Nikon/Product/Digital-Camera/26156/COOLPIX-S630.html
If, and only if my answer to your question is helpful, please rate my solution and leave a Positive Feedback.
May 31, 2010 | Nikon COOLPIX L20 Digital Camera
Lens error on Nikon coolpix S202
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Sep 17, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S60 Lens Error Message
since you said you dropped the camera the lenz array might have cracked. try tapping the device while the message appears, if it works then you are a lucky one. in no you have to take it to the service centre to get it done. it costs about (50-60)$
Jul 29, 2009 | Nikon COOLPIX S60 Digital Camera
Nikon Coolpix S202
My nikon coolpix s210 had a "lens error" after several months of use. The tapping of the camera against my hand did not work. Eventually i did use the method of putting my nail under the lens and pulling as I tried turning the camera on. I had to apply a good amount of force and was afraid i would break the camera, but after doing this several times, the lens did click back into place.
Jun 01, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S202 "lens error"
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 28, 2009 | Nikon Coolpix S210 Digital Camera
Lens Error.
nikon coolpix 4 lens error help!
Nov 11, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
57 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
