Question about HP Pavilion dv6000z Notebook
My laptop has come with Windows Vista, but Vista does not support may softwares. Can I change from vista to XP? How?
    Problem Solver:
  • 12 Answers
In order to change from Windows Vista to Windows XP you will need to purchase the Windows XP disk. Once you have purchased the disk you will need to reformat your computer. In order to do this click on Start
Click on Programs
Click on Accessories
Click on Command Prompt
type in Format C:\
answer Y to the prompt
Wait for it to format
Put the XP cd into your cd drive
follow the step by step instructions that come up on the screen
Posted on Jul 14, 2008
    Genius:
  • 2,785 Answers
Before changing just check the manufacture website for drivers then only change to xp
Posted on May 16, 2008
3 Suggested Answers
  • 33 Answers
SOURCE: i want to install windows xp sp2
It's a relatively simply procedure, 1st download all of the necessary drivers for your laptop from Compaq's website under the support section. You'll want the drivers for Window's XP. Either burn these drivers to a CD or place them on a flash drive. Also if you already have documents or data on the laptop that you would like to keep you'll need to back that up as well to either a CD/DVD or a flash drive.
Next you'll need a Windows XP installer disk. Place the disk in your laptop and reboot. The system should prompt you, asking you if you'd like to boot off of the CD press any key. Hit any key and the computer should boot from the XP CD. The system will take a while as it loads up the installer shell. If the system does not boot from the CD you will need to go into the BIOS or CMOS and change the boot order for the computer to make the CDROM or DVD ROM the 1st boot device. The 1st prompt on the installer should be a license agreement, hit F8 to continue. The next steps will pretty much be up to you. Things like where you want to install windows XP, do you want to format the drive, etc. This sounds like your 1st install so you may want to leave everything as default. Windows should detect your Vista install and by default install it as a seperate installation allowing you to boot into either OS.
After the OS has prepared the hard disk and copied all files the computer will reboot and will boot into a installer kernel and will prompt you for even more selections. This process will take longer than the initial portion and most of these settings you can leave at default as well. When this part is complete the system will reboot again and your installation of XP should be complete.
When the system boots into windows it will ask you to create a user name, create a user name or multiple ones. Put in your driver CD or flash drive and proceed to restore your files and install your drivers. That's the revised version of it anyway.
Good Luck!
Posted on Jul 10, 2008
rockitman187
  • 2559 Answers
SOURCE: my brother just gave me his hp pavilion dv4
First check the System requirements The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements vary, depending on system configuration and on the programs and the features that you install. If you install Windows Vista over a network, additional hard disk space may be required.
Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • 1 GB of system memory
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • 128 MB of graphics memory (minimum)
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
Note A Windows Aero-capable graphics card is a graphics card that meets the following requirements:
  • Supports a Windows Display Driver Model (WDDM) driver
  • Has a DirectX 9-class graphics processor unit (GPU) that supports Pixel Shader 2.0
  • Supports 32 bits per pixel
  • Passes the Windows Aero acceptance test in the Windows Driver Kit (WDK
If your computer is compatible follow directions below.
Option 1
loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
OR
Option 2
Note for the option below The computer must be configured to start from the DVD drive.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Please rate this a fixya
Posted on May 18, 2009
No drivers for windows xp sp2/sp3
You can download all of the drivers from the Toshiba website.
Nov 12, 2009 | Toshiba Satellite A205-S4777 Notebook
Tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 | Computers & Internet
Windows XP
use a vertualization software "vmware workstation" and you would be able to work on xp without installing it physically. this software is used to run several operating systems at one time.
link is http://www.vmware.com/products/ws/
you can use the trail version for 30 days
Jan 21, 2009 | HP Compaq 6720s PC Notebook
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
Hi there i cannot get my mp500 to work on vista please help kind regards teresa
Windows Vista This product can be used with Windows Vista.
  • To use it with Windows Vista, install the software for Windows Vista.
  • The Windows XP software for your product cannot be used under Windows Vista.
  • Easy-WebPrint and PhotoRecord do not support Windows Vista.
Upgrading from Windows XP to Windows Vista :
Beforeupgrading your OS from Windows XP to Windows Vista, delete / uninstallall the Windows XP software first; then, upgrade the OS to WindowsVista and install Vista software.
If you have already upgraded your computer's OS to Windows Vista :
Delete / uninstall Windows XP software before installing Windows Vista software.
For Windows Vista driver just click the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=11995#DownloadDetailAct
I hope it helps!!!
Dec 01, 2008 | Office Equipment & Supplies
Changing of Operating System
Yes there is no problem uninstalling Vista and "Downgrading" to XP just make sure you have a disc of the correct drivers first wich you can get here
Jun 27, 2008 | Microsoft Windows Vista Ultimate Edition
My laptop contains windows vista and i want to install Windows XP
i am using toshiba satellite l300model laptop. My laptop also contains windows vista. i want to install Windows XP as well. Some of my music software does not support Vista. Can you
please help me on how can i install Windows XP and how can i download the
XP drivers. I... Read more
May 20, 2008 | Computers & Internet
Navigator for pixma mp500
Before upgrading your OS from Windows XP to Windows Vista, delete / uninstall all the Windows XP software first; then, upgrade the OS to Windows Vista and install Vista software.
You can download from
Driverscollection.com
Mar 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
XP Downgrade
You need to start windows setup straight from cd. To do so you may need to change the boot sequence from bios.You will also need a bootable windows xp cd (not the upgrade version). Setup xp as new installation. Ensure you can get all necessary drivers and software for windows xp.
Hint: Vista works fine if it has enough ram memory, and you wont lose your valid licence and all software provided with vista.
cheers
Feb 16, 2008 | Computers & Internet
Change of os
it is not possible to upload xp when vista has already been installed.
if you want xp & vista both in your system
remove vista
install xp
& later install vista .
it is not possible to upload a olderversion(xp) when you have newer version(vista)
you can download windows xp from this link
http://www.soft32.com/download_992.html
Dec 18, 2007 | Microsoft Windows Vista Ultimate Edition
HP Pavilion dv6000z Notebook Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
