Question about Acer Extensa 5620 Notebook PC
My computer beeps constantly at start up and doesn't start up at all. I can only get it to start in safe mode.
  • 393 Answers
U need to replace the keyboard thanks
Posted on Sep 14, 2010
Et1862 stuck in elogo and restart with a beep continously
See if the computer will start in safe mode.
Steps to get in to safe mode: Make sure the computer is OFF not in sleep or hibernate mode.
Start computer and tap on the F8 key till you see a text screen that gives you the: Start windows in safe mode with networking.
Select that startup. If the computer doesn't start and you get the same beep - Then you have a possible hardware related issue.
If the beep is actually a number of beeps - this would relate to your system memory. Hope this help you in figuring out your issue.
Have a great night.
Dec 05, 2014 | Computers & Internet
Acer aspire zs600 Has Black Screen and Beeps 6 times, then repeats beep...
You might want to start in the safe mode. Right after you reboot your computer keep pressing f8 and it should start in safe mode. Once there you could then possibly see if you can solve the problem.
Good luck,
Marty
Jul 15, 2014 | Acer Aspire ZS600-UR308 - Core i3 3220 3.3...
Computer will not even start in safe mode
ed.you can't start a computer in safe mode.how old is the computer if 5 years or moore proberly the drives.iwish you had wrote moore exactly.as long the green blincking it's try'ing read shut it down let the hard drive cool of.
Apr 03, 2013 | Compaq Evo D500 PC Desktop
HELP! Acer T180 is possessed!
Have you Googled the beep codes? This is most likely your solution. You should do the RAM test on your system.
Blue Screen Of Death
  • Remove all USB attached devices.
  • You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
  • Uninstall last program(s) that was installed, again in safe mode.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM. Unplug PC. Opening case. Remove all RAM. Use static precautions!
  • Re-install Windows. Clean install works best. All data will be lost.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 04, 2012 | Acer Aspire T180 PC Desktop
My 531S hangs at the dell splash screen with one short beep before loading windows vista
I would start the computer in safe mode. To do this, keep tapping on the F8 key as you start the computer. Do this as soon as you see anything on the screen. If you get the windows splash screen, you've waited too long. Once you get the white menu on a black screen, choose safe mode and let it start. The next time you do a restart, it should work. If it doesn't, then in safe mode do a system restore back to the time it worked.
Apr 06, 2012 | Dell I531S-2809 PC Desktop
I installed a rompaq update on the laptop and it stopped working. what do i do? the laptop is so dear to me. pls help.
if the laptop was working perfectly before you installed the rompaq update, then it means the rompaq is the cause of the problem.
You need to perform a system restore in order to undo the installed rompaq.
Run your system in safe mode and perform the system restore.
To run system in safe mode, Turn on the computer and immediately, start pressing F8 constantly till a windows booting option shows up. Use the arrow key on your keyboard to select safe mode and press enter, then wait for the windows to load completely.
After the computer and successfully booted in safe mode, go to:
Start > All programs > Accessories > System tools > System restore.
Read and follow instructions. System will restart during the restore process.....
After that try again and observe of your laptop will function/work properly/normally.
Please let me know if this doesn't solve your problem so that I can help you further.
Regards.
Jun 12, 2011 | HP Compaq Evo Notebook N410c
My system is automatically restarting
Please make sure that all memory modules inside of the comouter are seated tightly.
If everything inside the computer seems intact and the computer still reboots try to go to safe mode and check if will do the same.
From shutdown, turn your computer on and start tapping the F8 key (F5 for some computers) when the menu appears choose either safe mode or safe mode with networking. check if the computer would still restart in that mode.
If it doesn't: press and hold the windows key on your keyboard then press the letter R, when the Run box comes up type in msconfig go to the services tab, tick Hide all Microsoft services and the click Disable All. Go back up to the tabs and click start up click Disable all then restart the computer.
If it still restarts in normal mode check if it's giving out a Blue Screen error.
If it still restarts in safe mode, shut the computer down and go to the BIOS.
From shutdown turn the computer on and start tapping F2 or Delete Key on your keyboard if both doesn't work check what key does your computer say to go to setup.
See wether if it will restart in the BIOS.
If it does, You may want to have the hardware parts of your computer checked.
If it doesn't my recommendation would be to reinstall yout operating system.
Hope you find these steps helpful!
Apr 30, 2011 | Intel Motherboard
My hp g6o stoped working right.How do I get to safe mode?
1. Reboot your computer
2. Press F8 constantly
3.Choose Safe mode
Thanks
DiegoTech
Nov 13, 2010 | Computers & Internet
I want to use safe mode
as you power the laptop on after the pretty little dell or hp screen start tapping the F8 key it may take a minute but keep tapping it til it comes up. then select safe mode.
Mar 07, 2009 | Computers & Internet
Acer Extensa 5620 Notebook PC Logo
142 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
