Question about Logitech Radio Communications
My microphone isn't transmitting sound at all anymore and it was working a minute ago. I saw some white paper around the wires and I thought it was messing up the wires so I removed that, still the same problem, I think that the plastic melted from the heat though but I can't say its true. Is the wire completely dead, I don't feel any electricity and there's no sound even on the taps of the microphone
MicrowaveSvc
  • 9098 Answers
SOURCE: faint buzzing sound smoke coming from back
The high-voltage transformer (or inverter transformer) has probably failed.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Nov 05, 2007
SOURCE: Dead refrigerator.
We weren't able to find a "Reset" button anywhere on the fridge, so I turned it off, unplugged it, waited 24 hours, and plugged it back in. The lights came on and I, then, turned it back on. It's working fine and keeping ice cubes frozen. Whew! That was a relief!
Thanx for your website.
Pat
Posted on Nov 17, 2008
  • 2976 Answers
SOURCE: What would cause white residue on plastic?
With the reformulation of detergents, it's becoming a common problem. You can try a liquid with water softener in it, and slightly hotter water. It might help. The environmentalists have made the manufacturers reformulate a lot of cleaning products to the point that, vinegar and water is almost as good as the newer detergents.
Posted on May 12, 2010
  • 674 Answers
SOURCE: Honeywell RTH230B cooling problems...
I printed out the instructions for your thermostat. It looks like you should have the following.
There should be jumper wire between Rh & Rc
Red wire to Rh or Rc whichever is easier since there is a jumper. This is the hot wire and all the thermostat does is connect to route it to the components needed for heating or cooling.
Blue wire, tape it up and don't use it. There is no spot on this thermostat for it. It is only used on thermostats that are powered by the transformer.
White wire to W. Powers the heat relay
Yellow wire to Y. Powers the cooling contactor
Green wire to G. Powers the indoor fan relay
There is a black jumper on the back of the face plate. Look at section 2.4 Setting J2 Jumper in the installation instructions. Make sure you have it in the right position for what you have. If you don't have them just google them.
Hope this helps.
Posted on May 24, 2010
SOURCE: My dog chewed up the
Hello,Yes there is a 3 amp blade fuse(same as in a car) in the blower unit,take off the door and it is plugged in to the(curcuit) board.Pull it out and slip a new one in.That will restore the control voltage.Your repair sounds correct.Some times there is a tiny button on the transformer itself (square box) that pops up instead of a fuse just push that in to reset it(if applys).
Posted on Oct 19, 2010
Microphone wiring
the rf power going out is geting inducted on the wires of the mic.try using some ferrites close to the coax on the pl259 connector and on the mic wire itself.
Mar 01, 2014 | Radio Communications
My microphone stopped working about 30 minutes ago after i tripped over the cord which unplugged it from the usb port. I can't figure out why it wont recognize input anymore.
1) Have you tried a new device in the USB port?
2) If so, and it still does not work, the port must be damaged.
3) If not, replace the mic.
Hope this helps!
Nov 02, 2013 | Dynex Audio Players & Recorders
Dose any 1 no how 2 wire a cb mike plug
Not familiar with with that microphone but here is the wiring for the radio's mic.....
#1 Shield (usually surrounds the white wire)
#2 White (this is the mic element wire +)
#3 Red (this is the radio's transmit wire)
#4 Black ( this the ground wire usually makes the radio receive)
Send me you email and I will help out more,..... poikaa@yahoo.com
Feb 07, 2010 | Superstar SS-3900EGHPA CB Radio
Acer One 8.9 Netbook microphone doesn't work.
If you say that the sound and mic was broken from the beginning, maybe the guys from the service didn't replace them. You cannot do anything by yourself. Try to give them the laptop back to fix it.
Nov 05, 2009 | Acer Computer AOA150 Notebook
Eighth in microphone jack/wire bad
You might want to check the other end as well. Take a ohm meter and check the wires to make sure their is a reading on both.The wire you speak of is called shielded cable and there should be no reading between the sheilding and the center conductor when they are seperated from the capsule. If there is a reading you have a short.To clarify, the outer sheild should read at or near zero when you check @ each end as should the center conductor ( the white ) wire.There should be no reading between the two (the sheild and the white) when they are unhooded @ each end. Also when the capsule is unhooded you should get a reading between the two terminals, if not the capsule is open and needs replacement.
Apr 05, 2009 | Sennheiser 100/500 G2 Series Wireless...
Does not receive FM signals anymore, just noise.
The T6310 is a disposable radio. Assuming the programming is correct, and matching on each of your radios, and you are using good batteries, there is nothing which can be done to correct the problem. We would however, suggest you double check your programming, and also the age of your batteries.
Sidenote: Rechargeable batteries only last 18-24 months before they begin to fail. Signs of failure can include, but are not limited to, poor transmit, intermittent transmit, white noise, squelching sounds. It takes more energy to transmit than to receive, so your transmit would be the first to go.
Nov 20, 2008 | Motorola Walkie Talkies 2-Way Radio
Microphone does not work
Yes, sometimes Skype messes with your hardware settings and sets it up to what "skype thinks works best", if you have System Restore turned on, try going back to the time before you installed that version of Skype.
Also, look in your Device Manager settings for anything screwy.
Dec 15, 2007 | Dell Latitude C400 Notebook
Standard Microphone Wiring
Pin 1 is Shield(most mics this wire is bare copper) Pin 2 is Audio wire(most mics this wire is white) Pin 3 is Transmit(most mics this wire is red) Pin 4 is receive(most mics this wire is black)
May 30, 2007 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
44 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
