Question about Midland WR-100 Weather/RDS Radio
When I press Weather/Snooze the radio emitts a high pitch sound like a whistling. I have the radio set to voice, I have verified the channel 162.4750 for my area. I have a scanner tuned to that same frequency and it works. I have double checked the County codes. Any suggestions?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
Solution #1
Some counties have two frequency channels. check this URL address to see if you have another frequency channel for your area- http://www.nws.noaa.gov/nwr/indexnw.htm. If you do, try the other frequency channel for your area.
Solution #2
You may be receiving a poor reception quality because of where the radio is located or the antenna's positioning. First play with the antenna until you get a better reception. If this doesn't help, try moving it to a location near a window or outside room. If this doesn't help, you may have to buy an external antenna from an electronics store and hook it up to your radio. If you still have your WR-100 Owner's Manual, they have a page in there for reception (page 12), and it lists in there their suggested weather radio antenna.
Solution #3
It may not be anything you've done at all. It could be the weather station's transmitter itself. May you should call your local NWS office and plea your case to them.
Posted on Sep 20, 2010
Weather radio just gives off high pitch squeal and no weather info.
If you hold the WEATHER/SNOOZE button and the VOLUME UP button, it resets the radio to its deafult factory settings.
Jan 20, 2012 | Midland WR-100 Weather/RDS Radio
The alert is to loud, how can I turn down the volume for the alert?
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
I have midland wr-100 weather radio. radio is programed with right codes and channel numbers all i get is a high pitch tone coming out of the speaker
Good morning, afternoon, evening or night; whatever time you're reading this. Thank you for choosing FixYa to assist you with your problem. The problem is that you are hearing a high pitch tone coming from the speaker. First check to make sure the weather mode is on. To do this, switch the radio to the right side and make sure the Weather Radio On/Off switch is switched to On. You should also check the alarm to make sure it's not on and set. If the alarm is on, turn it off. Your alert type may also be a cause for this. If your alert type is set on TONE, try changing it to DISPLAY or VOICE. Reply back if you still receive problems. Thank you for choosing FixYa as your one-stop solution spot for your problems. Have a nice day, evening or night; whatever time you are viewing this. Hope this helps and remember our site the next time you need troubleshooting assistance.
Why does my weather radio just beep, no voice, no lights? I have put in all codes for my county
Good morning, afternoon, evening or night; whatever time of day you are viewing this. You want to know why your weather radio just beeps and no voice or lights function properly. This has nothing to do with the codes you put in for your county. This has to do was the type of alert setting that is programmed into the radio. The alert setting that you have programmed into the radio is probably that TONE alert type. When this is selected, the alert will sound for 5 minutes or until any button is pressed except for the Weather/Snooze button. If you want your alert type settings changed, press MENU and use the up and down directional buttons until "ALT TYPE" is displayed on the screen. Use those same directional buttons to choose the alert type of your choice. If you choose DISPLAY, a text alert will scroll on your screen and no audio alert type will be sounded. If VOICE is selected, an alert will be sounded 8 seconds and you will hear the voice of the weather broadcaster for 5 minutes. These are the only other alert types you can choose other than TONE. Once you have chosen your alert type, press SELECT and and press MENU to exit. Remember that the NWS will only alert you if the storm meets their serve weather criteria (meaning the storm has to be able to cause a certain amount of damage or life threatening to "Wake someone up in the middle of the night"). With this radio functioning properly, it can really help you out in the long run by alerting you with the lastest information of what's going on in your area. Thank you for choosing FixYa as your one-stop solution spot for your problems and thank you for reading my solution.I hope this is the solution to your problem and it clears up any confusion you may have. Have a good morning, afternoon, evening or night; whatever time of day you're reading this.
Apr 04, 2011 | Midland Weather/Hazard Radio with SAME...
No weather information
It sounds like you may need to program your location into the radio. Follow these steps to do so.
1. Turn switch on side of radio to "ON".
2. Press "MENU".
3. Press "UP" arrow until "CHANNEL" is displayed.
4. Press "SELECT".
5. Press "UP" arrow until you hear the broadcast of your station.
6. Press "SELECT" to save station selection.
7. Press "MENU" to close menu mode.
To turn Weather/Hazard broadcast on again, press "WEATHER/SNOOZE".
Jan 02, 2011 | Midland WR-100 Weather/RDS Radio
How do I set for weather alerts
2. Press "MENU".
4. Press "SELECT".
Jan 01, 2011 | Midland WR-100 Weather/RDS Radio
Whenever I press the weather/snooze all I get is a constant tone, no voice
First, make sure you have a battery installed, and then run it off of the wall adapter. Extend the telescopic antenna all the way out. Go to MENU and then select the local channel for your county (channels 1-7 - use whatever channel is strongest). Once you select the correct channel, then hit the MENU button again, and then you should hear weather forecasts. Press the VOL UP or DOWN buttons to get the right volume for you. If you get to the 'CHANNEL' selection and still have a tone, then you have a defective radio that you will need to exchange. Good luck - let me know if you get it working okay. Happy New Year!
Dec 31, 2010 | Midland WR-100 Weather/RDS Radio
How do i program the radio to only give audio alerts for the county in whitch i reside? (sarpy county in nebraska
2. Press "MENU".
4. Press "SELECT".
Note you will hear only static on the channels not received in your area.
(FYI - channels are listed 1-7 on the left, and corresponding frequency numbers are displayed on the right side of display.)
At This Point You Will Receive Weather And Hazard Alerts Issued By The NWS.
Dec 24, 2010 | Midland WR-100 Weather/RDS Radio
We have had severe weather all day and it didn't go off. It had been working perfectly for a year. When I turn on the weather/snooze button I get a constant loud squeal on every channel. any ideas??
Check this website's FAQs page- http://www.crh.noaa.gov/lsx/?n=nwrfaq. Your answer may be in FAQ #10. It may be also that your local NWS transmitter may not have been receiving a good transmission because of the type of severe weather that you had. Maybe you should call your local NWS office and plea your case. I don't know if this will help, but this is my suggestion.
Sep 08, 2010 | Midland WR-100 Weather/RDS Radio
Manual
Hi, not sure why the manual I uploaded doesn't show up anywhere so here it is in 2 posts (too large for 1 post)
Stormtracker Vector Model: VEC438 Classified: UNOFFICIAL USE AT YOUR OWN RISK!
Programing Instructions
To Program Alert:
Turn the radio on and then press:
1. Menu button (may have to hold it a few seconds) and Alert should show in the Display.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: Voice/Siren/or Off.
3. Then use the Menu button to select between Voice/Siren/or Off.
3. After making your selection, press the Memory button to the left of the Menu button. This completes the programming of the alert function.
Example: If "Siren" is displayed on the LCD screen and you push the Memory button to the left of the Menu button, when a weather alert is broadcast the siren tone will sound and the appropriate yellow or red light will activate. If "OFF" is displayed on the LCD screen and the Memory button is pushed, the alert will not activiate.
To Program County
1. Menu button (may have to hold it a few seconds) and when ALERT appears, tap Menu button to scroll to County.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: All/Multiple/or Single
3. Then use the Menu button to select between All/Multiple/or Single (You'll need to know the S.A.M.E. codes for the area you want to listen to, otherwise select ALL and you will recieve "All" Statements, Watches & Warnings without having to select a specific County).
4. After making your selection, press the Memory button to the left of the Menu button if ALL was selected or Channel/Snooze button to the right of the Menu button if you chose Multiple or Single (You'll see CODE01 on the display) If you chose Multiple use the Menu button to choose which Code Position to enter (01-10) then press the Channel/Snooze button to the right of the Menu button. Enter the first digit of the S.A.M.E. code then press the Channel/Snooze button to the right of the Menu button to move to the next digit of the S.A.M.E. code. Repeat this for all digits of the S.A.M.E. code. Then press the Memory button to the left of the Menu button to lock in that code. Press the Menu button to select the next code position to enter. Then press the Channel/Snooze button to the right of the Menu button, then the Menu button to select the digit of the next S.A.M.E. code to be entered. Repeat these steps as necessary to enter in all the S.A.M.E. codes you wish to enter, each time pressing the Memory button to the left of the Menu to lock in each code position. When completed entering in all S.A.M.E. codes press the Memory key again to lock in all codes and return to normal operation. This completes the programming of the County Code function.
Example:
COUNTY SAME # NWR TRANSMITTER FREQ. CALL SIGN WATTS
Fulton 013121 Atlanta 162.550 KEC80 500
Colquitt 013071 Pelham 162.550 WXK53 1000
Colquitt 013071 Valdosta 162.500 WWH31 1000
NOAA Weather Radio Frequencies
162.400 MHz (WX2)
162.425 MHz (WX4)
162.450 MHz (WX5)
162.475 MHz (WX3)
162.500 MHz (WX6)
162.525 MHz (WX7)
162.550 MHz (WX1)
Channel numbers, e.g. (WX1, WX2) etc. have no special significance but are often designated this way in consumer equipment. Other channel numbering schemes are also prevalent. Best to just tune to the strongest sounding station in your area, this radio does not display frequiencies, only channel numbers.
NOAA Weather Broadcasts
Channel Frequency
1 162.550
2 162.400
3 162.475
4 162.425
5 162.450
6 162.500
7 162.525
A link to get the S.A.M.E. codes for your listening area: http://www.nws.noaa.gov/nwr/indexnw.htm
Aug 18, 2008 | Vector VEC438 AM/FM/Weather Radio
Midland WR-100 Weather/RDS Radio Logo
1,481 people viewed this question
Top Midland Audio Players & Recorders Experts
Van Allen II
Van Allen II
xxxxxx xxx
Are you a Midland Audio Player and Recorder Expert? Answer questions, earn points and help others
