Question about Vacuums
Have an A & T hydrobath which element has burnt out its an 1800 immersion model 180032m we replaced it approx 5 yrs ago I cant remenber if I have to unscrew it fro the inside of the washtank or thru the clipsal box on the outside of th unit - any suggections ??
Element has a nut on the inside which needs to be undone from inside the tank. The element then is removed from the clipsal box. Replacement elements are available from www.thebarfshop.com.au
Posted on Sep 14, 2010
No green light or steam Shark Deluxe Steam Mop, model S3202-S3202C
The heating element is burnt out, there is no repair for these models...replacement only...sorry!
Dec 30, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
On my kenmore central vac no power unplug unit plug it back green light comes on but try turning vac on green light goes off again .
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle.
If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point?
If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left.
If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100.
Please post back with your results
Oct 24, 2009 | Easy Flo EF1400 Central System Vacuum
Low suction
1) Have you checked the filter? If it is clogged your suction will be low. Also, you could have a pipe loose where you can't see. Make sure that you can get a coin to go all the way through the hose. make sure the suction motor ( the unit ) is coming on.
2) Call the repair man.
Aug 10, 2009 | Electrolux Central Vacuum
My Hoover carpet cleaner is approx. 7 yrs. old....husband believes motor is shot? Smells burnt when running....fix or buy new???
you are correct, the motor is shot. if you like the machine replace the motor. i would get an est. on the machine from your local vac shop and the go price them. in some cases its better just to get another machine.
Jul 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Burning smell kenmore canister
Had a burning smell coming from the vacuum. Opened it up and noticed sparks in the motor area. Ordered a new motor from Sears and replaced it. Works great now.
Mar 04, 2009 | Kenmore Vacuums
1800 vacuum cleaner belt replacement
Generic problem for all Vacuums
How do you get into the belt to replace it?
Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
http://www.dooyoo.co.uk/vacuum-cleaner/typhoon-1800-upright-vacuum-cleaner/1021772/
Apr 07, 2008 | Vacuums
Vacuums Logo
64 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
