Question about Sharp Office Equipment & Supplies
Is there a way to clean a Sharp fax machine? Unsure of model # as i am at home and it is at work. Persons receiving faxes have a dark, 1 1/2 inch wide line along left side of fax so unreadable.
  • 23 Answers
YOU HAVE PROBABLY GOT TIPPEX ON SCANNER. TRACE PAPER PATH TO SCANNER AND CLEAN IT WITH SOME METHS. DO NOT SCRATCH OR IT WILL SHOW FOREVER. SCANNER IS ALWAYS THE FIRST THING PAPER GOES INTO AFTER IT STARTS TO MOVE. IT LOOKS LIKE A LONG PIECE OF GLASS.
Posted on Sep 14, 2010
Blank print top 1 inch has print Toner cartidge has been changed
I need more information. If you make 20 copies do you still notice the problem or only when you receive a fax. What is your copy count (press life 1). Does it jam or make noises. At first glance I would say phone line problem. .
May 26, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax is received is very dark and almost unreadable
You can try using the menu to lighten the fax, but if all received faxes are dark, you may be experiencing a weak scan light. try making a copy instead of fax (which essentially is a fax printed to yourself) if also dark, its certainly your scanning imager that's failing. If that's the case I would recommend replacing the entire machine. Parts are expensive, and its a difficult to service part yourself. Also you may find that toner costs alone may pay for the replacement machine over this unit.
-Good Luck!
-FW
Jan 05, 2009 | Sharp Office Equipment & Supplies
Lines and breaks on docs received by other party.
Hi
If you have lines when faxing out it cant be the drum,If you have lines with copy and receiving faxes then it can be the drum.
I think you problem is a dirty scanner glass.Check the glass and clean.
Nov 18, 2008 | Office Equipment & Supplies
Dark Bar only on Sent Faxes
open the top where you insert the paper to fax look at the strip of thin glass is there any white out or toner on it that is most likely your line, clean
Nov 10, 2008 | Brother IntelliFAX 4100 Laser Fax
RE: SENDING FAX
The scanner glass is dirty or needs replacement. lift up the scanner door where you put original in. See the glass strip 1/2 inch by about 8 inches. clean with alchohol good. dry. test. Lawrence
Jul 18, 2008 | Sharp FO 77 Roll paper Thermal Fax
Receive faxes
In the receive mode choose tad. The fax will then distinguish between a fax and a call.
Feb 16, 2008 | Brother FAX-575 Plain Paper Thermal
Can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Dec 03, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
51 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
