Question about E-Machines eMachines Desktop PC
Cpu doesn't see the monitor - E-Machines eMachines Desktop PC
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 144 Answers
Check the cable line between cpu and monitor, check the power cable of monitor.
Posted on Sep 14, 2010
  • c_ozan Sep 25, 2010
    Looks like the video card has gone out and need to install another one. Looks like it is within the motherboard... Dont know much about these. Can I add another video card in since this one is attached to the motherboard.
  • kasinathan Anbunathan
    kasinathan Anbunathan Sep 26, 2010
    Yes u can add a inbuilt video card that suits ur monitor or look for some external card also
Acer aspire x1200 powers on but doesn't connect to monitor
  • Kindly check the cable that connect between cpu and monitor.
  • Re-insert RAM
  • Input Voltage if not connected using UPS.
Thank you for asking on fixya.com
Mar 20, 2013 | Acer Aspire X1200 Desktop PC - Athlon X2...
Pc not booting
If you hear the CPU fan turn on that doesn't mean the CPU itself is working. It can be only that the motherboard is getting power. Check all your connections such as monitor and peripherals and re-connect them. If you still don't get P.O.S.T. or ANY letters or boot options on your screen then your CPU is dead. (unless your monitor is bad)
Another easy diagnostic is using your ears. For example the pitch sound of the fan in some motherboards tends to lower and then increase because it's reading of the hard drive. This means your CPU is ok but either your graphics connection is bad or your monitor is.
Apr 22, 2012 | Intel Motherboard
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
TFT185W80PS monitor is not working
Check if your monitor power led indicator is on if it is, try to check the cables of your monitor if it is properly plugged to your CPU if it isn't plugged it properly if the problem still doesn't solve try to open your cpu and and uninstall your video card if you have a separate one and clean it with a pencil eraser then install it again and try it if it will work. But if your video card is built in, there is a problem with your video card or maybe your monitor try to contact a reliable computer technician..Hope it will help you.
Jul 02, 2011 | AOC widescreen 931SWL LCD TFT 19" Monitor
How do I connect the speaker cable from the cpu to the monitor - ca't find a socket at the monitor end H750
It appears that this monitor doesn't have speakers. You would need an external set of computer speakers. Most CRT monitors do not have built in speakers.
May 09, 2011 | Hansol 730 ED 17" CRT Monitor
No signal to monitor
Check all conections between the tower and the screen, make sure all are secure, if no joy, unplug the tower and remove the side panel to see if the graphics card is in securely, maybe take the graphics card out and put it back in again to be sure. If you have another monitor or monitor cable try replacing to see if the situation improves.
May 05, 2011 | Acer Aspire M1641-U1521A PC Desktop
I just bought Logitech Clearchat Premium PC, how do I get it to work?
Assemble it: connect the data cable from the monitor to the CPU, Connect the mouse and keyboard to the CPU, connect the power cables for the CPU and for the monitor, press the CPU power button, and the monitor power button. If the computer doesn't work, then it came without an operating system.Get the operating system disk and insert it into the DVD or CD ROM/RW drive. Turn the computer off, and turn it on again. Check the monitor carefully and when it prompts for pressing any key to boot from the cd, do so very fast. The process of operating system installation will start. Follow the procedures and instructions it gives you till the end. If you are not sure of any step, ask or consult any person who can assist.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
E-Machines eMachines Desktop PC Logo
24 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
