Question about Kenmore Dishwashers
Model 363-1404898. Motor Hums but will not start. What is the problem?
2 Suggested Answers
braindead56
  • 5 Answers
SOURCE: Push start and motor hums, but nothing else works.
Hey, either the belt is broke or something has happened to the tensioner pulley so remove front or rear panel & visually inspect & if belt is broken look & see if part # is still visible on belt surface & order a new belt.
Posted on May 12, 2009
My Frigidaire fex831fs4 washer motor hums but wont start.i took belt off.still hums no start even when timer is not set to run.if I close lid motor hums then kicks out then it trys again.thanks 4 help
I appreciate your post, Mike!
Based off what you have described your Frigidaire washer motor will hum and not start. In order to test each component you would need to have the proper electrical equipment. I would recommend contacting a professional technician for proper repairs. They will have the necessary equipment needed to complete your repair. Hopefully this is helpful. -Matt
Aug 31, 2015 | Frigidaire Dryers
Pump hums, but does not start
bad start up capacitor or motor
May 18, 2014 | ADVANTAGE Pool & Spa
Dryer motor hums but does not turn when start button is pushed
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 24, 2011 | Maytag MDG6000 Dryer
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
Jan 23, 2011 | GE Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
Dryer won't start. Hums
This is usually caused by a motor that has gone bad. The hum is caused because the motor windings have gone bad inside the motor and its cheaper to buy a new motor and install it yourself if your capable. Its pretty straight forward once you see it. Be sure to disconnect any power supply before working with electrical. You will need the model number and sometimes serial or date of mfg. Sears and other dealers are good about finding your part. Be warned, the cost of a new dryer might not be far off from the price of a new motor. Hope this helps.
Dec 28, 2009 | Washing Machines
Liftmaster - motor hums, doesn't turn. Removed
My neighbor guy, who knows a lot about stuff, told me to get a new one.
Good solution.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Model DLE3777W - Dryer hums when I push start button.
The drive belt for the drum may be broken and should be replaced.
Jul 18, 2009 | Dryers
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Neptune dryer model 4000, <10 y.o., hums, but won't start.
I wouldn't know about the warranty, but the dryer motor may need only a start relay, which is usually attached to the motor. Usually, this is a centrifugal device. By that I mean the contacts on the relay are normally closed to give the motor extra starting capacity when you first turn it on. The contacts open after the motor get up to full speed.
Jan 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
