Question about GE Kitchen Ranges
Hi the oven bottom element to my ge profile jbp79viaa is not heating up.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Sep 14, 2010
My ge profile oven is 18yrs.old never had a problem! all of a sudden the oven is not working , my cook top is fine, what do you suggest? thank you doreen
in the oven there are usually two heating elements. one is on the bottom which is the one mostly used and one is inside the oven but on top of the ceiling of the oven compartment. (this is used for broiling food) if you set your oven to broil, check to see if the heating element on the ceiling of oven is red. I almost bet it is. normally the bottom element will go out. these can be changed.
Apr 07, 2011 | GE Ovens
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
Ge double oven, no heating
check that u have continuity through the elements if you dont then replace the element next if you do have continuity through both elements check to make sure you have power coming from the main control to the element if you dont have any power leaving the control board then replace the control
May 18, 2010 | GE Profile JTP56 Electric Double Oven
How do I change the top heating element on a G.E. Profile double oven JKP54G0P1BG
the heating element should have 2 screws in, when removed pull the element towards you then pull off the 2 wires,replace in reverse order.
Sep 30, 2009 | GE Profile JTP18 Electric Single Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
