Question about iRiver H10 MP3 Player
When i boot the player, i get System files missing
  • DanceInPA May 11, 2010
    Iriver H10 5GB screen says "USB Connected" and drive letter (F:) for it appears in Windows Explorer, but no driver for it appears in Control Panel/Administrative Tools/Computer Management/Storage/Disk Management. Right-clicking F: in Windows Explorer and selecting format does nothing either. And attempts with firmware upgrade and recovery tool do not seem to recognize the H10 as being connected. What next??
    Scholar:
  • 193 Answers
Go to controll panel administrative tools system maneger select the second option then the 3rd..ul see ur driver right click and format
Posted on May 15, 2008
  • mike nasr May 12, 2010
    did u get any driver/cd with the product?
    did u tried to acces it from command promt?
    do u know how to use live cds? like puppy linux?
Acer 6920 missing 2 registry files and can't auto repair or start. Hard drive has only 25 gig space left. Are there some files I can download to repair without wiping the hard drive and starting o
If you have the Vista disk, insert it into the CD Rom player. When it starts it will ask you if you want to repair or install a fresh copy. If you choose repair, it will fix any missing registry files
Jul 28, 2012 | Acer Aspire 6920 Notebook PC
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Something cldr file missing it shows.my system cannot able to boot up.its gigabyte system.
Use the operating system CD/DVD while booting & select option to repair the operating system. You need to know the password for Administrator. The missing file will be replaced.
sonsunny
Jun 14, 2011 | Computers & Internet
Will noy boot up
some of your operating system files is missing/corrupt, that's why the main windows cannot open/load.
You will need to repair your windows operating system (win xp/vista), in other to solve this problem.
To repair your windows, you will be needing a windows operating system CD, insert it into your player and run setup. While you are installing, it will get to a stage where the system will ask you if you want to restore, click restore and the missing/corrupt files will be reinstalled.
Good luck.
Jun 13, 2010 | Toshiba Satellite A135-S4527 Notebook
I can not get my system boot up it says Windows 32 /system file missing.......... what to do
Your operating system seems to be Corrupt. you need put windows xp Cd and repair the windows
Apr 21, 2009 | Computers & Internet
Restore the system files, connect H10 to recovery tool
The procedure depends on what version you have.
Below there is the procedure for 20 GB , on other models procedure is the same, but you must find the right download for your model.
For 20 GB :
TO RESTORE "SYSTEM FILES MISSING" LOCKED PLAYER
--- This applies ONLY to the 20 gig version of the H10! ---
--- This procedure formats your H10 so all data will be erased on the player! ---
1. Power off H10 - 20gig unit.
2. Insert staple or other small object into reset hole to press reset button.
3. Connect player to USB cable.
3. Hold down Select key (labeled "O" - right button on front of player) while also holding down power key until player boots.
4. Unit must display "Emergency Connection."
5. Unit will now appear as a drive under My Computer. Right click on drive, select Format. No need to change anything, just proceed.
6. Download H10_20GB_System.exe. It is a self-extracting archive. Double click on it and unzip to c:\iriver.
http://www.iriveramerica.com/downloa...0GB_System.exe
7. Locate iriver directory, double click. You will see H10. Double click once again; you will see System.
8. Right click on system, select "Send to" and choose the directory of the player.
from System Files Missing
If you have the 5 or 6 GB see iriver - H10 5/6 GB Series Support
Feb 24, 2009 | iRiver H10 MP3 Player
No system boot files
seach for PVRDATA on your software disk and copy it to the device in windows - works fine
Nov 26, 2008 | Goodmans GPDR40 Digital Media Player
Windows dont start
It means that some files needed for windows to restart are missing,probably a system file or boot files. Some windows xp users usually re-install and repair their windows xp system using their original windows xp install disk and selecting the "repair" ooption. But another practical solution is to note down the missing file, then,on another PC using the same system,search for that file and copy, though you will have to note the folder location of that missing file from another PC. Boot your PC (the one that doesn't boot) with a system diskand on the command prompt (DOS prompt) copy the missing file from yourcopy disk to the same location where the missing file should be situated.
If the practical suggestion wouldn't work, then you have to re-install your windows on top of the current installation using your windows cd to repair yourwindows sytem, if this still doesn't then you have to install a new windows systemlocated in a different location in your disk, this way you still go to your saved files and backup your files.
Apr 18, 2008 | Microsoft Windows XP Professional for PC
Winxp cannot boot - missing files message
probably corrupted operating system files. i'd suggest doing a fresh reinstall of windows xp. if the problem continues then get a new hard drive.
Dec 27, 2007 | Computers & Internet
Start up
without knowing which file is missing, you will need to repair windows, this is probably a boot.ini file that is missing. You will need to go intothe bios of your system (F2 or DEL on boot up) and in the advanced cmos settings, make your cd drive the first boot, device and insert your windows cd, save settings and exit. The system will reboot and ask you to press Enter to boot from cd. allow windows to install all the system files and in the next option, press 'R' to repair the files.
May 27, 2007 | ASUS P4S800D-X Motherboard
iRiver H10 MP3 Player Logo
75 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
