Question about Samsung DualView TL220 Digital Camera
I plug my camera into my computer and it asks me if i would like to connect to computer or printer. when i click printer, the camera turns off and nothing uploads. Ive had this camera for 3 months with no problems until now and nothing has changed.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Mar 31, 2011
How to install network printer
Go to "Start" on any computer on your network.
Choose "Add a network, wireless or Bluetooth printer."
Choose your Canon printer from the list of available printers.
Select "Install Driver" if prompted.
(OR)
If you have any issue while installing Call on Printer Tech Help Support Toll-Free number 1-855-887-0097.
Sep 27, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Have E Machine ET1161-05 trying to install Kodak ESP6150 computer does not find printer
While installing the printer just switch off the printer and try to install the printer driver completely, When the software will ask you to connect the printer then only switch on the printer. If this way still you are getting the same problem then connect the printer in other usb port or use different USB cable
Aug 14, 2012 | E-Machines eMachines Desktop PC
I have connected to my PC. The camera asked to select USB computer or printer. When I select Computer the screen on the camera goes black and nothing appears to happen. The light on the cable is red. Can...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 19, 2011 | Samsung L100 Digital Camera
When I connect my camera to the computer I don't get a popup window asking what I want to do with the camera. When I first got the camera there was no problem but after getting a new HD and reinstalling...
1) click on start 2) click run 3) type " devmgmt.msc " in the open box and click OK make sure camera is connected and on in the playback mode. 4) look for " Imaging Devices " 5) click on the + in front of it and you should see the camera. 6) click it one time to highlight it ( not open it) 7) now right click and choose delete or uninstall 8) it will warn you just click OK Now camera in uninstalled 9) close all windows and turn camera off. then turn camera back onn if will find camera and give you options you are looking for
Jun 14, 2009 | Canon PowerShot A620 Digital Camera
Scanner on my "All in One HP 6110" refuses to work any longer
Please get back to me with the following information to assist you further.
  1. How is your printer connected to computer? (USB or Network)
  2. Have you installed Full feature software?
  3. If you are connected with USB cable make sure the cable is connected directly to the printer without any USB hubs.
  4. What is the OS?
  5. Are you able to copy a document on the printer (stand alone copy)?
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Camera will not read on the computer.
You shouldn't need the driver - Turn the camera on, Push the menu button - click right for "setup"
you will see animation, beep, frequency, format, default , etc.... scroll down to USBMODE and click ok. Then plug it into your usb that should already be plugged into your computer. A screen will pop up asking what you want to do open folder with pictures in it, etc.... if this doesn't work E-mail me and I'll send you Coach Drivers that will work. Put the camera in usb mode though and it will work. I had the same problem.
Aug 19, 2008 | SVP DC-12V Digital Camera
Scanner installed but getting message can not communicate with pc
Have you loaded the scanner driver software on your PC? Is the printer connected to the PC using a known good cable plugged into the proper receptacles? Is the scanner plugged into a known good power source? Is the scanner turned on? If you use one of the USB ports, your PC should automatically display NEW HARDWARE FOUND on your screen, and willl then ask if you want to install it using the SCANNER AND CAMERA INSTALLATION WIZARD.. You can also left click mouse on WINDOWS START, left click on CONTROL PANEL, and left click on the SCANNERS AND CAMERAS ICON. A new window should appear. Follow the instructions on this SCANNERS AND CAMERAS window, and you should be able to get your scanner working.
Aug 04, 2008 | Office Equipment & Supplies
Transfering pictures
if your running windows you can go to my computer and check if there is a removable disk double click on it and you can manually copy and paste the pictures to the folder.
Jul 20, 2008 | Nikon COOLPIX P4 Digital Camera
Cant download pictures
- install the software
- restart computer
- connect camera to PC, but make sure camera is turned off
- after connecting the camera, and the computer is ready, turn on the camera
- select Computer on camera LCD
- go to My Computer
- click on Removable disk
- click on DCIM
- click on 100SSCAM
- select all the images and copy them
- select a folder where the images will be saved
- paste the images
Jan 01, 2008 | Samsung Digimax S700 Digital Camera
Scanner not working
Please open HP director from Start - All programs - HP .
Click Scan document to scan.
You can scan by following steps :
For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
Waiting for you reply.
Thanks
Dec 22, 2007 | HP PSC 2355 All-In-One InkJet Printer
Samsung DualView TL220 Digital Camera Logo
47 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
