Question about Mitsubishi Televison & Video
Wt46807 tv projection black box show up after 8 seconds. change channel it goes away then it comes back
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This can come from either the set or a box connected to it for signal.
Under closed captions either the set or the box is set to TEXT--never used but many sets have this feature---check the menu in the set first and then if using a box for signal check there.
One of the two is causing this.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have questions, comment here and I will assist you.
REGARDS, SD TECH
Posted on Sep 13, 2010
Projection TV. DVD works. Cable often seems, "untuned". Static & un-fine-tuned sound of channel with black screen. Then, later, it will come on just fine. Sometimes, will go back to untuned status.
I would suspect your cable box first. I would unplug the power cable from your cable box and wait 60 seconds. Plug it back in and try to watch cable tv. I would also make sure the coaxial cable going from the wall to your cable box is connected properly. I would also make sure the cable going from the cable box to the tv is connected properly. Test your tv and see if it works correctly when you watch cable. If this fixes the issue you are good to go.
  • If this makes no difference use a set of new cables if you have them.
  • If this does not work then call your cable company. They may have to replace your cable box.
May 25, 2015 | Televison & Video
Black box in middle of tv screen
This is a background for text, even though you aren't seeing any text at the time. Since it covers most of the screen, it sounds more like a demo mode screen than closed captioning. Go into your setup menu and make sure that neither of those is selected. If necessary, restore the factory settings. I'm assuming that this is coming from the tv itself, and that you don't have a VCR, Tivo, etc. Good luck!
Jun 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Black box
Good Day,
With black box, get the TV's remote and turn OFF the "closed caption". You are in the text of your cc. Good Luck, big IRISH.
Jun 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Blacked-out box covering 75% of screen
shut off close captioning. the close captioning is in text1 mode and needs to be CC1 in order to work, or shut it off
Mar 25, 2008 | Hitachi 51F500 51" Rear Projection...
When a black box appears on the screen it means that your closed captions are on and set to TEXT. When the closed captions are set to CC1, it puts the words on the screen and when set to TEXT it puts a black box in the center of the screen. Go into the set's menu, navigate to the closed captions page and set the captions to OFF.
Aug 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Black Rectangle Appears on Screen
Perhaps the caption is on?
May 27, 2007 | JVC AV-27220 TV
Televison & Video Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
