Question about Kenmore Vacuums
I have the top of the line kenmore canister vacuum. According to the bottom plate the model nimbler is 116.28015700 I was doing the normal vacuuming and the bag full light came on and the vacuum action stropped. There is still power to the mortorized handle and agitator attachment. Is there some type of circuit breaker reset button for the vacuum function? This unit is probably less that two years old and has had very little use
reddevil6
  • 1673 Answers
SOURCE: can't figure out how to replace the bag
Open the hood, bag #20-50557 , the cardboard part goes in the bag holder, will only fit in one direction, then close the hood.
Posted on Jun 22, 2008
SOURCE: model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Model 116 hose clog?
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
advacak
  • 125 Answers
SOURCE: kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Posted on Dec 03, 2008
  • 382 Answers
SOURCE: How to replace Kenmore canister vacuum filter.
I believe it faces toward the housing
Posted on Dec 19, 2009
I cleaned the filter and emptied out the canister from the bottom and now the dirt comes out on my filter and not in the canister?
The first place the "dirty" air enters is the top chamber of the canister where it traps the bigger stuff.
The canister has two clean-out doors so make sure you open them both (top and bottom) or you could have problems.
Nice thing about the Shark as it has a number of clean-out points starting at the base of the hose where it enters the bottom of the vac. to the beater brush (on the bottom of just behind the brush assembly). Good luck!
Mar 16, 2015 | Shark Navigator Bagless Upright Vacuum
How do I open a Panasonic Power Nozzle to replace the belt? The Vacuum Model # is MC-V9635
The top part of the nozzle pops off just put small screw driver on side and lift up under the top lid is 2 screws then pop off by putting screw driver on sides to lift the housing off base plate
here is roller
Sears Kenmore Brush Roller 8192670 8175102 And 742454
and roller
Sears Kenmore And Power Mate Canister Power Nozzle Belt Part 20 5285
Jul 05, 2014 | Panasonic Vacuums
I want to disassemble a canister vac model #5561209 for cleaning. Vacuum bottom plate says to check manual for instruction. Can't find manual for instructions...:)
I can't find the manual for that model number. Here's the Kenmore site with most of their models.
Double check the number, and type it into the given space. Again, that model number comes up blank. Googling it also provides no hit.
http://www.hammerwall.com/Manuals/Kenmore/Description/116.31913/Kenmore%20Vacuum%20Cleaner/L0403208/
However, I did find one for the 55612-90, which may be what you want, or at least very similar (55612).
http://www.hammerwall.com/Download_Manual/60467/
Mar 02, 2011 | Kenmore Vacuums
I need a model number for the kenmore durapower vacuum. Don't have the manual can't find on vacuum
Hi There,
The model number will either be located on the bottom or the back of the machine on a sticker that also contains the serial number. All vacuums have to have this sticker, and serial number information on the machine somewhere. On uprights it's usually on the back of the machine towards the bottom, or on the very bottom of the floor nozzle part. On canister vacuums the model number will either be found on the bottom of the canister, or on the bottom of the power nozzle.
Hope this helped!
Chris
Apr 20, 2010 | Kenmore Vacuums
My canister kenmore progressive is not sucking and is sptitting carpet powder dust all over the place. could it be it needs a new hpa filter? if so where on the vacuum would it be located?
Remove the hose from the canister, and turn on the vacuum. Does it produce good air flow into the hose port?. If ok, remove the hose from the sweeper unit and plug the end into the canister. If ok, check the bottom of the sweeper head for plugging of the air passages and inspect the sweeper bar for accumulation of thread, hair, and string. If the first test produced no air flow, then open the canister and remove the bag--turn the vacuum on and check for air flow into the motor. If still nothing, then check the hepa filter which should be near the air output from the canister. Go to: searspartsdirect.com and enter the sears model number from the information plate. The machine's part drawings will appear and select the vacuum case drawing which should display the hepa filter location and also be able to order the filter from the web site. Hope this helps!
Mar 13, 2010 | Kenmore 25512/ 25513 Progressive Canister...
How do I replace the belt on my Kenmore canister vacuum?
Turn the power brush over so the bottom faces up. On the bottom there are two access screws. Remove the two screws and then the top cover can be removed from the base. With the top cover off you can access the belt. You can get a replacement belt for your model here:
Kenmore Progressive Replacement Belt
Nov 17, 2009 | Kenmore 25512/ 25513 Progressive Canister...
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister power-mate
I was able to get the whole thing reassembled.  If there is something specific that you are having trouble with let me know.  Everything snaps into its specific spot--it is just tricky to get it all lined up.
Sep 19, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Powermate Canister Vacuum Cleaner
Depending on which model, there is a couple of scres on the bottom, then on each side and back are release catchs that you pry up to release the top, then you can get to the belt. The other model you take off the light cover, it just snaps in place, then you can take out 2 screws from the top, on each side there is a slot, put a screwdriver up into the slot and pry out to release the tabs, then the cover comes off and you can get to the belt.
Feb 10, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Kenmore canister model 116
Yes. Remove the top plate on the power head. Remove the two screws. Flip the power head over. Insert a flat head screw driver into each of the marked slots and separate the two pieces. It takes about 2 minutes.
Dec 20, 2007 | Kenmore 22812 Bagged Canister Vacuum
Vacuums Logo
44 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
