Question about Cycling
Front crank sprocket clicking on bycycle, when I pedal the front crank sprocket clicks, it isn't the pedals.
  • 186 Answers
Make sure all sprocket bolts are tight.
check chain to make sure you have all rollers between links are there.this can make a clicking noise or skip teeth if one is missing when you pedal.
if you feel clicking in the pedals (even if you think it isnt the pedals),then it could be your bottom bracket bearing gone.
put one pedal towards the floor and stand on it.did it click?then try the other pedal.if you got it to click then your bottom bracket is loose
Posted on Sep 14, 2010
Rear wheel clicking
Could be caused by worn wheel bearings if the clicking is not intermittent. If the clicking only occurs when pedaling and sounds rhythmic, this could be caused by the chain and/or sprocket. Some 6 and 7 speed sprockets are renowned for this rhythmic sound under pressure but it doesn't seem to be a serious problem.
Apr 21, 2014 | Huffy Cycling
The pedal makes a clicking noise
If it's a fairly new pedal, I would remove them and try a different set of pedals to make sure that it definitely is the pedal. Assuming the different set doesn't click, then you may have a warranty issue. If the bike is still clicking, you may have to check the crank and bottom bracket next. The tough thing about clicking noises in the bottom bracket area is that there are a lot of parts that can be causing it and you just have to eliminate them one by one.
May 05, 2012 | Shimano PD-A530
I have a NordicTrack SL710 recumbant bike that the pedals slip and make a clicking noise?
Prepareto oil by filling a grease gun with lithium grease. Check your owner's manualfor the exact type of grease for your unit.
Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack SL710 pedals slip and make a clicking noise?
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
The pedals will turn but the wheel does not
The rear set of gears, called the "Freewheel" are shot, and need to be replaced. You can find another wheel, but this will probably prove to be difficult, or you can pay for a new freewheel or your bike shop may give you an old one for a discount.
Good luck
Joe
Aug 29, 2011 | Cycling
I don't understand how to shift my 12-speed Adventurer bicycle and am looking for online manual or some help. The right-hand shifter has numbers 1-6, but I don't seem to know how to match it up...
It sounds like you have 2 sprockets on the Front (Crank) sprocket-
and likely 6 sprockets on the rear?
So-- when you have the chain in the smaller diameter sprocket on the front, and you have the chain on the biggest sprocket in the rear-- you have the most mechanical advantage-- and you can climb hills the best-
If you started in this gear, (sand you are pedaling on the level road) you could gradually work you way up thru those 6 sprockets-- until you are cruising-
Then -- for all practical purposes, you can shift the Front sprocket to the larger sprocket, and now you have at the fastest ratio possible. (In other words you pedal slower, for a faster rotation of the rear wheel-- make sense?)
There is no need to switch back and forth 12 times, as you go gradually faster-- (It is not like driving a big truck! :-)
Does this help?-- if not, let me know what I missed in your question?
Mack B
Jul 04, 2011 | Cycling
I would like advice on adjusting the rear derailleurs on my Campag Record long cage set. I am very much an amateur, and am not sure which screw/nut to turn and by how much. Thank you.
ok...there are usually 2 screws,one above the other.The top screw normally adjusts the deraileur so that the deraileur does not touch the spokes.the bottom screw usually adjusts the derailer so that it does not go past the smallest sprocket.One way to adjust eg(incase you have clicking sounds as you pedal) is to put the deraileur into the smallest sprocket at the back end.Flip the bike upside down so it sits on the seat and handlebars.Now get right behind the deraileur and see if the deraileur is in line with the smallest sprocket.If it is not in line,then slowly pedal the bike and adjust the screw inwards until you hear no more clicking.If you cannot get into the smallest sprocket,then,turn the screw outwards while still turning the pedals.The deraileur will slowly move outwards until it jumps into the small sprocket and no clicking sound .Vice versa for the top screw.good luck.let me no how you get on
Nov 14, 2010 | Campagnolo Chorus 10 Speed Short Cage Rear...
Hi trying to re grease the pedal sprocket bearings on my Ross Rock Machine mountain bike. I got off the pedal arm on the right side but can't figure out how the left side comes off. The pedal arm looks...
Bottom brackets are sealed, removing the seal will have potential for damage. If it's making noise, replace it or better yet upgrade as a crankset. You'll have new crankarms, bottom bracket, chainrings with it. Unless you have the correct bicycle tools (not general automotive tools) you won't be able to pull your crank and even reach the seal for the bottom bracket. Click here for tools you need to do the job.
Jul 03, 2010 | Ross Rock Machine Aluminum Mountain Bike
Clicking crank when pedalling - new bearings or crankset?
More diagnosis on your part required. Unless the crank is hitting something in its rotation (like the errant end of the front derailleur cable in the path of the right crank), clicking will be a bearing and not the crankset itself. Now, is it the bottom bracket or maybe just a pedal?
You could remove or drop the chain onto the frame (shift to the smallest chaninring first, then cover it with a cloth to protect the frame) and manualy rotate the crank without touching the pedals, feeling for the click, maybe even place your ear against the seat tube to hear it better.
If you have toe clips or clipless pedals try to generate the click by pedaling with only one leg at a time. That might reveal a pedal issue or which side of the BB is dying.
Mar 22, 2010 | Cycling
I want to replace the main sprocket with a bigger
you need to pull the pedal off on the side that the crank is on the pedal will thread off like a bolt but the threads are reverse on the pedal once you have the pedal off you will have to unscrew the two nuts that hold the crank in the frame of the bike the inner nut is easiest to get off with a flathead screw driver once you have those two out you can pull the crank out of the frame and then you may want to put it in a vice because the crank will turn off the pedal unit but you usually have to pry up on the crank a little to get the alignment pin out of the crank enough to turn it
Jun 08, 2009 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Cycling Logo
229 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
