Question about MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb assembly out the top so I can use a dow to tap the batteries out? If not, how can I get them out? Thanks for any help you can give.
Well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Posted on Mar 31, 2013
  • 67 Answers
SOURCE: 2AA LED Maglite not working
The Led are most likely not burned out they last 10,000 hours or more. Sounds more like defect.
Posted on Sep 23, 2009
  • 121 Answers
SOURCE: how do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Posted on Oct 07, 2009
SOURCE: Mini Maglite LED not staying on
I tried the usual steps of cleaning the contacts and replacing the batteries and elongating the springs, and none of it worked. In solution #2, the poster describes removing the circuit board, which I did. I found that the inductor coil on the board had broken free and was unsoldered on one side. A little superglue and a quick dot of solder fixed me right up.
Posted on May 06, 2010
  • 75 Answers
SOURCE: How to replace witch assembly in rechargeable Maglite?
1st, remove the battery via the **** end of the barrel.
2nd, carefully remove the little RUBBER CUP that covers the depression off/on switch. Gently maneuver it out by lifting the edge of it then pulling it out. Do not cut or puncture it. This little rubber cup keeps water and dirt out of the switch.
3rd, Remove the HEAD (light assembly) off where the charging rings are, just behind the switch. Hold the barrel with one hand and with the other twist the head until it begins to unscrew from the barrel and until it is free. Upon completion of this step, set the barrel aside. If you have a digital camera you can photograph each step of this so that when you reassemble, you can simply refer to the photos for reverse order assembly.
4th, Unscrew the LENS CAP and set it aside. At first it may seem as if it is not unscrewing but keep going as it will come off. Upon completion, set the lens cap aside.
5th, Hold the BULB with a tissue and pull straight out with out twisting. Do not hold these types of bulbs with your bare hands as the moisture and oils of your skin can damage the bulb when the switch is turned on. Upon completion secure the bulb and set it aside.
6th, You will now be left holding the BEAM ADJUSTMENT HEAD which also contains the OFF/ON SWITCH.
7th, Firmly hold the ADJUSTMENT HEAD (the large portion) in one hand, then place the small end in the palm of your other hand and push the small portion through and out of the large portion. Set the head aside. You will now be holding the short barrel which contains the bulb holder and the OFF/ON SWITCH.
8th, Now look at the OFF/ON SWITCH. You will see a white plastic cylinder looking up at you. When you push it down you will hear and feel it 'click as it is engaged in the 'on' position. This and the assembly it is contained with-in must now be removed from the short barrel containing it.
*CAUTION* When you finally ( In step #9 below) remove the SWITCH from the short barrel, the assembly containing the switch itself will want to 'spring' apart into two halves because it is under slight pressure due to the spring which puts tention on the OFF/ON button. Hold it firmly until you have it completly removed from the short barrel. Pay attention as you do this so that you can remember how to put it back together at reassembly time.
9th, Using a small common tip screw driver, depress the WHITE plastic OFF/ON button as far down as it will go. While you are holding it down with the screwdirver use the thumb of your other hand and push against the BULB HOLDER, this will cause the SWITCH assembly to move forward about 1/4inch and to the point where you can release pressure on the switch with the screwdriver. At this point DO NOT continue pushing.
10th, look down into the barrel where the white plastic switch is that you had depressed in step # 9. You will see a BLACK plastic housing which holds the WHITE OFF/ON SWITCH. Using your small blade screwdriver, slide it behind the BLACK plastic housing and gently apply a prying pressure which will force that housing containing the SWITCH assembly, to move forward and exit the short barrel containing all of this. REMEMBER! It is at THIS point that the two-part housing holding the switch assembly will want to 'spring' apart. Pay attention and go slowly. When you reassemble this part of the flashlight, know that in order for the switch assembly to go back into the short barrel the WHITE PLASTIC OFF/ON button has to be DEPRESSED, do it with the screwdriver, enough to clear the interior side of the barrel. Depress it and gently push the assembly back into the barrel until it is back where it began. Be sure to line up the male notch on the exterior of the switch housing with the female grove of the interior of the small barrel. If you have the notch lined up and the switch button depressed all the way it will slip right into place with a happy clicking sound.
Upon completion of that step, reassemble the rest of the components in reverse order.
There you have it. Good luck. :)
Posted on Apr 24, 2009
  • 34 Answers
SOURCE: HOW DO YOU PUT A BULB IN A MINI-MAGLITE?
Unscrew the lense, pull bulb out replace with new one. Normally an extra one is in the end cap in a plastic tube. be sure not to touch new bulb with hands use a tissue.
Posted on Oct 10, 2009
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
Is there a mini Maglite Led pro that takes 1 AA battery
Not that I know of- they are usually 2 AAs. The 1 AAA keychain model was terrible in that the "turn to on" function was intermittent so I could never trust it. Tried WD40, sanding the contacts, etc. This was the old halogen version.
Sep 03, 2015 | MagLite Mini Pro LED Flashlight with...
Where do I send my Maglite for repair?
hello
the warranty details and the address are here Albert. Good choice in flashlights, but you may wish to look at LED units. The technology has moved on, and Cree LEDs are incredibly bright for the size. Some comapnies make LED modules for Maglight. I have one.
http://www.maglite.com/repaircenters.asp Repair Centers Mag Instrument Inc Manufacturer of the Maglite Flashlight
Jul 29, 2014 | Mag Instrument AAA Mini Maglite...
Mini Maglite end, where batteries are changed will not open. Is it the same as the D Cell Maglite; ie. the batteries have leaked? If I send it to you can you fix? Thanx, Peggy P Losee
You can send it direct to MagLite for warranty/repair
Go to: http://www.maglite.com/repaircenters.asp
to find the nearest warranty/repair center.
Gary
Jan 11, 2011 | MagLite Mag-Lite& Flashlight
I cannot get the cap off to replace the batteries of my mini maglite 2 cell AA
Probably a leaking battery has coroded the cap. You can send it direct to MagLite for warranty. Go to: http://www.maglite.com/repaircenters.asp
Gary
Nov 14, 2010 | MagLite Mag-Lite& Flashlight
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Sep 23, 2009 | MagLite Camping, Backpacking & Hiking
I found this site because I too have a pile of these with that problem. I have had maglites since the time when they weren't available to the general public and have always liked them. These new LED lights are great for the light/size ratio and I was very sorry to see this product perform so poorly. After reading the comments here I went to the Maglite site and found some troubleshooting tips. Believe it or not I fixed the one in my hand and can't wait to go fix the others. They really need to spell out on the package how the LED unit works when the batteries get low. Apparantly when they do get low the unit won't dim, it will completely shut off. You turn it off and then back on again and it flashes on but then stays off. According to the troubleshooting there is a bit of electonics in this unit that will shut the unit off if the battery voltage falls below a certain threshold. This appears exactly like a poor contact problem. I thought I had try battery replacement on some of my units in the past. The toubleshooting section does also cover other possible issues and shows how to try to fix them - not a bad document. Here is the link - good luck - I hope they stay in business. I think they need to address this issue somehow or else they will silently loose their market share. http://www.maglite.com/pdf/CustServ/Mini%20Maglite%20LED%20FAQ5222007805552.pdf
Jan 27, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Corroded batteries stuck in a mini AA maglite
yes the bulb assy can be removed as it's basically the switch you need like a special tool for removing it. but first which brand of battery is in it. both energizer and Duracell have warranty about replacing item that the battery has damaged. try that route is my suggestion before trying to remove batteries and possibly breaking the switch. you can get one sent to you by calling up customer service as i replaced one before mini mag lite also.
Oct 04, 2008 | MagLite Camping, Backpacking & Hiking
Maglite LED. Light switch is intermittent. Have had the same issue with my 8 month old 2AA LED Maglite, don't have receipt and have tried finding a solution to get it fixed again. Lost my temper with it...
Unfortunately not, I've seen more and more of these coming back to the shop here with faults. Mostly they seem to be connection problems like yours.
Pity, MAG are excellent and have really tarnished their reputation with this LED gimmick. A lot of the customers who return their LED's to us take a traditional MAG as a replacement..
Sep 01, 2008 | Camping, Backpacking & Hiking
MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color Logo
948 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
